Heavy Sedan + Manual trans + turbo 5.3... Can it work?
So it is time to move on from the setup that I'm currently running, and I'm leaning towards a smaller cube turbo setup.
Currently I'm running a 10:1 LS7 with forged pistons and stock rods. 2.9L Whipple 14-15psi on E85. At 4,000lbs the car has gone a best 9.98 @ 146 and trapped a best of 147. The goal is to push even further but I've decided I've pushed the LS7 far enough and fear losing the entire motor if I lean on it even harder.
That brings me to now. I see a lot of success with the iron motors and have dabbled with the idea of forged internals in a 5.3 with a single turbo. I want it to make 150+ mph power but don't want to ruin the fun factor on the street. The manual transmission is going to stay in the car regardless of what I do next.
Any input regarding turbo size and/or if this is even feasible to make work well with the manual transmission?
I have considered that as well. I just plan on running quite a bit of boost and don't want to worry about headgasket issues. 6.0 isn't out of the question at all if the added cubes would truly help significantly and not sacrifice durability
6.0 will also open you up to more head choices and 317 heads are common on them, Are you looking at a junk yard type build or full build?
It's hard to beat cubic inches to get something heavy moving, I would also assume more cubic inches and less boost would make the same power and live longer than a smaller engine with higher boost.
As far as the trans goes, If it will hold the power then I don't see a problem. You'll likely give up a little at the strip and you can really nail the shifts. I would think a 800-100hp on the street would be fun with a manual or an auto.
Get a LY6 and rebuild it for boost.
I've have over 7k in my long block and using a 5.3 block versus a 6.0 might have saved me $600 but how much power would I give up?
I don't know that a 5.3 would hold more boost than a 6.0 to me it seems like dialing in the tune is going to be the deciding factor on either combo.
If it's heavy.
Do a aluminum 5.3 or aluminum something.
Don't make a heavy car heavier.
But also with that being said it's harder to go fast in a turbo stick car.
In my opinion when compared to a blower stick car.
I wouldn't stick an iron block in there, that's for sure. The car is already heavy enough.
An aluminum 5.3 block will give you plenty of strength with the thicker cylinder sleeves, and you could stroke it to 359ci with a 4" crank easily enough, especially if you were already thinking about forged internals.
The 4.8/5.3 heads can be loaded with 1.95/1.575 stainless steel valves and ported for fairly cheap, still flowing 280+cfm, even on the 3.78" bore. And Tony Mamo has an amazing small bore MMS205 head that would definitely be worth checking out for a build like this.
Even if you don't stroke it to 359ci, an aluminum 5.3L with some forged guts, good heads, a custom cam, and a single S480 turbo should be about perfect.
I have no experience in this so just asking. Would it help to go to a 4.5 Whipple if you want more power/higher boost? He has the hole cut in the hood already. At what point do you start seeing a befit going to the larger blower?
You don't. Or he wouldn't. Not without sleeving that LS7 block.
Dude with the silver GTO took a 4.0L Whipple about as far as it can go. Had terrible belt slip issues trying to break 1,000hp. Kept breaking snouts on the blower and belt tensioner brackets, **** like that. Point is, now his GTO has a turbo or two, because for that power, turbos are just better. Plain and simple.
With the heavy car, a bigger motor just makes sense in almost all respects apart from a sturdy base block.
But no reason why he couldnt do an LS3/LSA say 416 or so for sensible money ( obviously never as cheap as a 5.3 ) and still make 1k+ with ease.
Take a look at what the likes of AGP are doing with the Gen5's and their turbo kits, ADM Performance etc.
Twin 62's on a stock 5.3 should get you 150MPH. I'm not sure you want instant spool on the street, just blows the tires off.
Something I didn't see mentioned is that a ctsv doesn't weigh nearly as much as a Silverado or even a suburban does and the 5.3 does just fine in those with a heavier drivetrain. My old 5.3 rcsb drove just fine. Would it have benefitted from boost or cubes or both? Sure but it worked without.
I think a properly speced and boosted 5.3 would do great. Even with an iron block.
You are correct that the CTS-V weighs less than the 5.3-equipped trucks, and I am sure a boosted 5.3 would move a V1 just fine. I was advising the use of an aluminum block for better weight distribution front to rear, mainly. But less weight is free power, even moreso "free" than just cranking up the boost. You can still add an extra pound or two of boost to an aluminum block AND weigh 85# less. Think about it...
That was my dilemma starting out. I wanted to go fairly quick for the lowest cost so I got a cheap engine and a cheap turbo and let them eat. Hard to beat getting an engine and turbo for $1050 which so far has held up to a years worth of beating. But I know that "free ride" of sorts will be over at some point so I went ahead and spent more to build a block to have on standby with the goal of reliability down the road.
