Boosted 4.8
Old Mar 27, 2016 | 10:12 PM
Ajc313's Avatar
Default Boosted 4.8
I have a 4.8 wanting to do a forged rotating assembly. What options do I have? What's an ideal compression ratio? What is better blow through or efi?
Old Mar 27, 2016 | 10:45 PM
JoeNova's Avatar
Restricted User
Just put a turbo on the stock engine and run it.........
Old Mar 27, 2016 | 11:06 PM
67Firebird455's Avatar
^^^ Agreed. What are your particular goals? What kind of car/truck is this going in?
Old Mar 28, 2016 | 09:10 AM
Ajc313's Avatar
I've read that I need to gap rings bigger? Or do I just let it ride?
Old Mar 28, 2016 | 09:11 AM
Ajc313's Avatar
I'd like to make 600-650rwhp in a single cab s10
Old Mar 28, 2016 | 09:24 AM
Black89Z51's Avatar
Put some valve springs, maybe a cam, slap a turbo on it and let it eat.
Old Mar 28, 2016 | 09:28 AM
denmah's Avatar
Moderator
pump + meth = no reason to open the motor
Old Mar 28, 2016 | 09:50 AM
Ajc313's Avatar
I was thinking about the ljms stage 3 turbo cam
Old Mar 28, 2016 | 10:32 AM
Black89Z51's Avatar
I would talk to Lil' John and tell him what you want so he can recommend the right cam. You want a cam that will compliment the turbo via exhaust events. Going to the biggest may not be the best.
Old Mar 28, 2016 | 11:04 AM
JoeNova's Avatar
Restricted User
Way too much cam for a 600hp 4.8.
Just boost the stock engine. Throw an On3 7665 on it. It'll spool quick and make good power. From there you can do upgrades as you wish. No point in going all-in on your first build. There will be problems. Dont spend more money than you have to the first time around.
Old Mar 28, 2016 | 02:35 PM
DavidBoren's Avatar
The motor probably has enough miles on it to loosen up the rings, so you don't have to worry about that. New valve springs and injectors are all you really need. The stock intake, stock cam, and stock rotating assembly will all be fine for those power levels. Throw a cheap turbo on there and drive it.
Old Mar 28, 2016 | 03:08 PM
Ajc313's Avatar
Motor had 250,xxx
Old Mar 28, 2016 | 03:11 PM
JoeNova's Avatar
Restricted User
You're still going to get the same answer. Turbo the stock engine....
Old Mar 28, 2016 | 04:20 PM
Ajc313's Avatar
Thanks for all the input
Old Mar 28, 2016 | 10:41 PM
Beanslsxnova's Avatar
I wouldn't touch the rotating assembly. I would put a cam/springs in it and go. I had a 220k 4.8 in my car all last year and it never missed a beat. 14-20 lbs of boost for 2500 hard miles and it was still running fine when I pulled it out a few months ago.
Old Mar 30, 2016 | 05:40 AM
rkreigh's Avatar
Motor had 250,xxx
I'd hone it and throw some fresh rings abd bearings in it.
250k is alot of miles and I'd be surprised if it has good cyl sealing
putting a turbo on a worn out engine isn't a good idea.
If I was going to boost a stocker, I'd look for a bit fresher short block than that.
Old Mar 30, 2016 | 06:17 AM
Black89Z51's Avatar
Denmah just pulled apart a quarter million mile motor where the rings were damn near new and the other motor he had had bearings with as many miles on them that looked like they were put in yesterday.
There's no reason for any of this work. If anything, valve seals, springs and a cam and slap it back together. There's been too many builds identical to what the OP is trying to achieve that have succeeded with less. I don't think I've read a single JY turbo build that was done where someone had to yank the motor because it was worn out.
Old Mar 30, 2016 | 06:27 AM
JoeNova's Avatar
Restricted User
Don't listen to him. Just boost the stock motor.
Old Mar 30, 2016 | 10:44 PM
massconfusion's Avatar
+1, I changed the springs added an ls6 cam and head studs. That's it 4K street miles at 15psi sometimes 17. I run it hard through the first 4 everytime I drive it. Mine is 5.3 but same ****
