Compressor Wheel Radial Play
Old Mar 30, 2016 | 05:27 PM
Shownomercy's Avatar
Man-Crush Warning
Default Compressor Wheel Radial Play
Preface, sorry about quality, pic taken with a potato.
Journal bearing, older 76gts
Thoughts on that? It will catch a finger nail but the wheel looks to be free from damage so IDK what to think. I can move the shaft slightly up and down but IDK how much play is allowed.
Old Mar 31, 2016 | 01:01 PM
oscs's Avatar
Pull it now. Any contact on the cover is a no no
Old Mar 31, 2016 | 01:49 PM
Man-Crush Warning
Amazon.com: Garrett Precision Turbonetics Big Shaft Turbo Rebuild Kit: Automotive Amazon.com: Garrett Precision Turbonetics Big Shaft Turbo Rebuild Kit: Automotive
Worth the gamble?
Old Mar 31, 2016 | 02:00 PM
oscs's Avatar
If you can get it back in tolerance than yes. Problem is you should get it balanced.
Old Mar 31, 2016 | 02:03 PM
Man-Crush Warning
Which is the only reason rebuild shops can justify the ~300-400 to rebuild it.
Stuck on what I wanna do with it.
Old Mar 31, 2016 | 03:20 PM
oscs's Avatar
Yup. A few places around here charge around $100
Old Mar 31, 2016 | 03:25 PM
stevieturbo's Avatar
I've seen plenty of turbos where contact has been visible last 100k, so that alone isnt necessarily a problem.
And if you DIY rebuild, as long as the turbine and impeller are bolted back in the same position, balancing is not a concern.
Really though, some new turbos are so cheap, I'd just run it until it does **** itself, then upgrade.
Old Mar 31, 2016 | 05:52 PM
Man-Crush Warning
The main reason I am thinking of rebuilding is that perhaps this scuffing is the noise I am chasing
I will link that thread later when I get on a laptop
Old Mar 31, 2016 | 07:10 PM
An out of balance shaft can make a whistling noise, the actual contact probably wont make noise. Or some problems with the impeller also make a whistle, ofton more noticeable during spool up.
I know the thread you're referring to, although i simply couldnt hear anyhthing in the video.
That contact does look very very light though.
Old Mar 31, 2016 | 08:03 PM
69-chvl's Avatar
I think the impeller on my turbo NEW would hit the housing if you put pressure on it. But once the oil wedge gets around the shaft it should center itself.
I'd run it.
Old Mar 31, 2016 | 08:34 PM
oscs's Avatar
OP this is one of the times when you shouldn't listen to everything you read on there Internet. Think about it for a second.. That turbo needs a rebuild. It's really that simple. You are risking a lot letting it slide. Just my .02
Old Mar 31, 2016 | 08:45 PM
Man-Crush Warning
I know, and to be honest, it will get sent out for peace of mind. But, forced inductions said they won't touch it and I reeeeally don't want give it back to pte. Work turbos said he could rebuild and I have been talking to a place in Detroit that will do it.
What concerns me is either a) pte holds it hostage and says it's required to have $800 of repair b) shop other than pte cobbles together the rebuild cause pte doesn't sell rebuild kits
Should have stayed stock.
Old Apr 1, 2016 | 05:57 AM
Well certainly the first part of that statement is true.
I've seen turbos with markings worse than that run well beyond 200k. Many things can cause shaft movement during operation that may see some contact with the volute...it's no big deal.
Hell even my YSi did it, and it runs on a fixed bearing system so there should be...and was no play. But air moving back/fro etc can cause the blades to move. It's a simple reality and can have nothing to do with the condition of the bearings used.
And given JB turbos are already fairly loose to start with....really it is no big deal.
But by all means if it is a concern have it looked at...but as you say if they do come back with say $800 or so....how much is a brand new BW that will offer better performance ?
But I'd have no concerns running it and even if it fails it's no big deal unless it leaves you without transport.
Old Apr 1, 2016 | 06:22 AM
Man-Crush Warning
I do not think I could fit a BW unit, even if there was a smaller T4 frame one.
Old Apr 1, 2016 | 06:59 AM
True...they're usually pretty big.
Old Apr 1, 2016 | 07:13 AM
Man-Crush Warning
Sucks cause for the rebuild price I am prob halfway to a base model BW S400 lol
Or be brave and grab a PT88
Old Apr 1, 2016 | 08:21 AM
oscs's Avatar
[QUOTE=stevieturbo;19209138]Well certainly the first part of that statement is true.
Great advice! last post was 100k
That's because they are riding a a cushion of oil! of course they are going to be "loose" when they are stagnate.. I mean come on man..
You cant possibly be serious? No concerns running a compressor at 100k RPM that is making significant contact with the housing? You clearly have never seen what happens when a turbine blade makes contact and snaps off.
OP there is one thing that is clear as day. Its a hell of a lot cheaper to rebuild the turbo than it is to rebuild your motor. Risk vs. Reward
Old Apr 1, 2016 | 09:30 AM
Clearly you've never worked on too many turbos if you think that's going to cause his impeller to fall off.
And by your reckoning the turbo is fucked anyway, so makes no odds anyway.
Old Apr 1, 2016 | 09:58 AM
oscs's Avatar
Wrong. I've seen it happen more than a few times that's why I'm amazed you would suggest it. It's not worth the risk and shitty advice advice at best.
Old Apr 1, 2016 | 12:30 PM
Man-Crush Warning
Looks like I am gonna send it to Reed and go from them. At the very least I get an unbiased opinion on what may have gone wrong and evaluate.
