4.8 turbo choice.....
Old Apr 23, 2016 | 01:28 PM
sbcgenII's Avatar
When are you going to start building this thing?
Old Apr 23, 2016 | 04:15 PM
LSOHOLIC's Avatar
Already started...lol.. Only have had the truck 3 weeks...already tinted, lowered, debadged and wheels on the way.
Have the pump and injectors from other project that were not used. Also, already have the 2.25" v-banded 6.0 manifolds.
Need to buy the turbo, wastegate, T4 flange, BOV, a2a, cam & springs. Will have Ralstons or Gray fab up the hot side and I'll run the cold side and mount everything.
And about the turbo....the impeller will be on par for anything the sbe 4.8 can handle. It's the hot side that will make or break the combo. Impeller is only efficent as the hot side allows.
Old Apr 23, 2016 | 05:36 PM
sbcgenII's Avatar
Who did your manifolds? I don't like mine. I didn't know ralastons would build a hot side for you?
Old Apr 23, 2016 | 05:41 PM
LSOHOLIC's Avatar
A buddy welder for Bizjet. TIG 308 rod....slow cooled. Actually look pretty nice. But it won't matter much, all getting wrapped.
I've had Ralstons do all sorts of oddball projects....just have to be a little patient.
Old Apr 23, 2016 | 09:55 PM
kingtal0n's Avatar
Originally Posted by DavidBoren
The ignition cut vs fuel cut discussion is quite interesting, more research is required on my end before I can comment on either.
We can use some common sense here I think.
Imagine you installed an injector to the exhaust system. Spraying it when the engine was hot, would generate a nice loud backfire, a burst of pressure and temperature would blast through the exhaust system at high speed. This is typically considered performance boosting, i.e. you are pushing energy into the exhaust system.
As a down side, you now have this extra explosion for your parts to deal with on that side. Temperatures may get higher than they would normally, gaskets see more fire and pressure than they normally would, and of course the valves have to deal with it as well.
Daily driver (longevity) applications should avoid this extra explosive character, but for racing/performance some folks "need" it.
Old Apr 23, 2016 | 11:51 PM
LSOHOLIC's Avatar
So let's look at it strictly from a turbine discussion.
What is the correct AR and turbine wheel size for a 4.8 on E only turning 6500rpm (X amount of exhaust gas at X rpm) ??
8.8 SCR
8.2 DCR (roughly)
Events
-4
36
43
-5
Here is an example of exact same turbine sections with different impellers.
- 4" Air Inlet
- 2.5" Compressed Air Outlet
- 72mm Wheel Compressor
- P Trim .96 A/R Turbine
- 102.4mm/72.1mm Compressor Wheel
- 74.1mm/64.6mm Turbine Wheel
- 3" V-band Hot Side
VS
- 4" Air Inlet
- 76mm Wheel Compressor
- 102.4mm/76.7 Compressor Wheel
- 74.1mm/64.6mm
What does the wisdom say ??
Old Apr 24, 2016 | 09:30 AM
sbcgenII's Avatar
Is that a stock48 cam?
I don't know anything about how the 4.8s do turbine and cam wise. But 5.3-6.0 and 75/75 combos can go 5s at a decent weight. Those turbos "on3" are so cheap just try one and if it don't work get a turbonetics hurricane series "68 turbine" or anything a on3, turbonetics or prescion 75 turbine wheels.
The 68mm wheels seem to sputter out at 5500 rpm with the bigger motors so a 65-68 turbine may be perfect with the small cam and stroke.
Old Apr 24, 2016 | 01:06 PM
kingtal0n's Avatar
the design of the exhaust system will have a large impact on which turbo will work best. So will the converter/clutch, weight of the wheels/tires/driveshaft/flywheel, the type of fuel quality 93/E85( and spraying meth or not), whether using nitrous or not, weight of the vehicle, types of temp control you are using (blankets, shields, reflections, coatings) the big list is big
If you are using junk turbos then forget about calculations. Junk is junk, just try it, it will probably only last a few weeks then you get to try another one
Old Apr 24, 2016 | 02:03 PM
LSOHOLIC's Avatar
Those events are just a break down from a.......
212/218 112+2
212* @ 0.050 and a 36* IVC is plenty for 293" cubes @ 6500rpm.
Jarrett will spec you what ever you want. Don't think he has "a cam". He made the Isky triple 12 popular with the results from his builds but....it's whatever the combo wants IMO.
With this combo.....it's a balancing act. Don't want to load the motor to early in the rpm (mechanically limited) and don't want to spin it to high (for many reasons).
So, in saying all of that.....70mm or 72 or 76...etc. They all will feed the 293" cube motor all it wants. It's matching the exhaust characteristics that will allow the impeller to do its job efficiently.
Old Apr 24, 2016 | 02:12 PM
LSOHOLIC's Avatar
I'm OCD when it comes to attention to detail. So yes....I will obsess with all the little things (number of bends, bend radius, thermal efficiency, a2a shrouding, priority wastegate location, large down pipe, minimizing all restrictions especially pre-turbo...etc).
The "cheap" turbos have proven themselves time and time again. A well designed oil feed and drain back as well as possibly a turbo timer should go a long way as far a dependably and durability are concerned.
But....I appreciate all the detailed talk but I'm really only seeking input for a properly sized AR and turbine wheel for a 4.8 with the details I've previously stated. I have a very strong handle on the rest of the project.
Thanks...
Old Apr 25, 2016 | 09:27 AM
JoeNova's Avatar
Restricted User
Thanks...
Typically, nobody listens to him anyway.
Jarrett's triple 12 cam and the On3 7665 are a solid combo for a 4.8. Lots of low-mid range, and extremely fast spool. If you want more power, spend a few extra bucks for the On3 7875. You'll trade a little low end for top end, and still have tons of mid-range power.
Old Apr 25, 2016 | 12:40 PM
  #32
LSOHOLIC's Avatar
The 3x12 is a proven winner...but I'm leaning towards a tad more exhaust duration (218*) for the sake of inefficiencies in a stock exhaust port, valve size and cheap turbine section.
Thanks for the turbo recommendations....
Not to derail my own thread.....but looking at the trans situation, dollar for dollar....I'm considering just doing a 80E swap vs dumping $$ into a limited life 60E.
Old Apr 25, 2016 | 12:59 PM
  #33
sbcgenII's Avatar
Are you sure adding exhaust duration with a small turbine is the way to go?
Old Apr 25, 2016 | 01:11 PM
  #34
JoeNova's Avatar
Restricted User
Its really not...
And my stock 80e is still taking an absolute beating. A built 60e advertised the hold the power I'm making is like $3500+ core.
Old Apr 25, 2016 | 01:36 PM
  #35
LSOHOLIC's Avatar
I'm basing my judgement on the few turbo builds (rock crawler/ TEO4H) I did, which were not performance based. And N/A, n2o stuff that I currently tinker with.....
More duration and an earlier evo "should" help...
The blow down cycle, pumping losses and...what I've seen is, as compression becomes higher the peak cylinder pressure tends to drop off more quickly. So there is no need to hold the valve closed longer, it only hurts the other cycles. And IMO, this is how you start increasing your VE & BSFC ( by helping other cycles, it's all about managing compromises)
So....8.8 scr & 8.2 dcr...with 15 to 20 psi on top = effective compression ratio. Gunna guess and say with my local elevation and average d/a that the effective compression is in the high teens or low twenties.
I would not be surprised to see the cylinder pressure completely fallen away 25* ATDC
Also....I can find several quote's from Urban & Duttweiler stating early evo reduces back pressure and helps with spooling (two guys who know their craft).
Old Apr 26, 2016 | 09:17 AM
  #36
LSOHOLIC's Avatar
What's your guys thoughts on a T4 1.10 AR with the 212/218 112+2, 4500lb truck and a 3000-is convertor ??
My initial thoughts are....the convertor better be perfect...lol.
Probably run very well once in boost but.....that 4.8 will be hating life trying to get up on the convertor (to bad it's a 99% street deal, dump valve would shine in a situation like this).
Because if I don't go cheap on the turbo.....I'm leaning towards a cast 475 (t4, 1.10, 83 wheel).
