Low hp #
Old May 5, 2016 | 03:01 PM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Originally Posted by dropedss86
Would that cause low hp numbers
It sure can, big time. If you have black dust all over the blower then you have belt slippage. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old May 5, 2016 | 03:08 PM
AnotherWs6's Avatar
Looks like belt slippage. I'm no expert but when you see those squiggly lines that should be the first thing you investigate. Hopefully that's all it is. Subscribed in hopes you find an easy fix and post new #'s.
Old May 5, 2016 | 03:12 PM
JoeNova's Avatar
Restricted User
The real question is, was it still making boost when the belt was slipping or did the boost drop
Old May 5, 2016 | 04:52 PM
dropedss86's Avatar
I did not have dust that I could see but I still tightened the belt and on my boost gauge it held 6 psi and spiked to 7 before I had to get off it. I am not sure if it was fluctuating on the dyno.
Old May 5, 2016 | 04:58 PM
93camaro_zzz's Avatar
When you say that your AFR was "spot on", what was the actual AFR?
