Low hp #
Old Apr 28, 2016 | 05:43 PM
dropedss86's Avatar
Default Low hp #
I just installed a d1sc on a bolt on Ls1 it was pushing 5-6 ps1 and it only put out 366 last time I dynoed the car without the d1sc it put out 344. The tune looked good and the graph is smooth. Afr was right on. I am running the 6 rib setup. From what I found online I would think I would put down closer to 450
Old Apr 28, 2016 | 06:08 PM
alocker's Avatar
That sounds about right. See the turbo vs supercharger thread. .
What was the AFR? Did you boost leak check it before the dyno? Post up a graph.
Old Apr 28, 2016 | 06:13 PM
dropedss86's Avatar
I did not boost leak I will have to search to see how to do that. I would think I would get more hp with 5 psi than 20
Old Apr 28, 2016 | 09:28 PM
Razor's Avatar
Somethings not right.
5 psi and 22hp gain over n/a?
Old Apr 28, 2016 | 09:41 PM
Forcefed86's Avatar
slipping converter?
Old Apr 29, 2016 | 05:25 AM
helga203's Avatar
Sorry but 5-6 lbs of boost will not get you 450hp. You need to be around 10 ish.
Old Apr 29, 2016 | 05:45 AM
LS1-IROC's Avatar
Are their trees on the planet you live on? 6lbs on a bolt on LS1 should have no problem hitting 450rwhp. He has a problem in the system.
Old Apr 29, 2016 | 06:14 AM
forcd ind's Avatar
Could be a lot of things, converter, tire spin, etc-where were you taking the boost readings.
Sometimes dynos are not friendly to certain combos, but the weight/MPH tell the truth.
Old Apr 29, 2016 | 06:24 AM
dropedss86's Avatar
I think he was getting the boost # from the map sensor.
Old Apr 29, 2016 | 06:46 AM
Forcefed86's Avatar
Check the RPM VS vehicle speed to see if the converter is slipping. What brand converter is it?
Old Apr 29, 2016 | 08:30 AM
dropedss86's Avatar
It was a Performabuilt converter I will call the tuner to see if I can get the logs I am not sure if he saves them
Old May 2, 2016 | 10:13 PM
dropedss86's Avatar
Here is the dyno sheet I am wondering if it could be valve float or weak springs. What should I log in my hp tuners to get to the bottom of this
Old May 2, 2016 | 10:42 PM
soloman369's Avatar
Need more info on setup . What kind of fuel pump and injectors. You said reading boost off map sensor you don't have an actual boost gauge. You got a log of the run and I'm not talking about the dyno graph. Like rpm,tps,ltft etc...
Old May 3, 2016 | 06:06 AM
dropedss86's Avatar
I do not have a log of the run I did not think about asking for one I am running Semans 80 lb injectors and a Aeromotive 255 with hotwire kit hopefully the weather clears up so I can make some pulls and log
Old May 3, 2016 | 06:31 AM
alocker's Avatar
What springs are in there? I initially thought springs but the power usually drops off when you float. Your chart drops a bit but is still climbing at 6K.
Old May 3, 2016 | 06:52 AM
GJS440's Avatar
My car with a stock 99 LS1 with a D1sc, 60# injectors and a 255 pump, Brute speed blower cam and comp cam valve spring kit on 8.2# boost made 543rwph through an auto.
Old May 3, 2016 | 07:34 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
The squiggly lines towards the peak hp look to me like belt slippage. The 6 rib blower belt has to be as tight as a guitar string. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old May 3, 2016 | 07:35 AM
dropedss86's Avatar
It's stock springs
Old May 3, 2016 | 08:03 AM
dropedss86's Avatar
Would that cause low hp numbers
Old May 5, 2016 | 02:59 PM
rpturbo's Avatar
It would be a contributing factor for sure.
