Alternator question! urgent
Its a turbo 408 setup.
so far made 706whp on 11psi...e85 14 degrees of timing. turbo 400. hoping for high 7xx on 11psi when all said and done for now.
http://www.ebay.com/itm/380600040302?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
LS1 Camaro Trans Am One Wire Alternator 98 99 00 01 02 | eBay
I am running a factory ls1 alternator and plug...nothing has changed.
My question is do i need to replace it with a factory one or switch to a larger AMP truck alternator...but i guess either way i have a problem with the ALT. lol Might as well do truck alt and see what happens.
Definitely regulator related somehow but no idea why. Got fucked off with them in the end and bought a 170A unit from these guys. It's been faultless since. Although I did have to put a small spacer on the bracket as it wasnt quite a direct fit.
https://alternatorparts.com/ad230-ad...ternators.html
Ideally, we'd all have a heavy guage ground wire from the alternator to the battery. (Car audio guys do this) the alternator case is a major part in the charging/ground system. I make sure to have clean metal contact surfaces at all alternator and ground wire contact points.
You can't have too many grounds.....
