CR for procharged LS1
Old May 25, 2016 | 12:33 PM
Firehawk173's Avatar
Would the scat Pro comp I beams work for 600-700 rwhp? Also looking at luanati H beams but don't want to spend an extra 250.
Old May 25, 2016 | 12:59 PM
conan's Avatar
I would spend the money now. You will want to turn it up at some point. Build everything to handle more than you think you want now.
Old May 26, 2016 | 08:27 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
I'm with the other that have posted that recommend going with the front mount instead of the twin intercoolers. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old May 26, 2016 | 08:30 AM
LS1Tech Sponsor
Originally Posted by Firehawk173
Thanks for the advice will call around when I get to that point.
We built Bob Johnson's CTS-V at the old EPP shop. LS2/402, my blower cam http://shop.brutespeed.com/Brute-Spe...d-Camshaft.htm, AFR 225 heads, 9.5/1, LS2 intake and F-1A at 14.4 psi. It made 809 rwhp We then swapped the intake for a FAST 92 and we lost 2 psi of boost but hp went up to 864rwhp. This engine has been together since 2009 and is still running great. Bob drive's this car on trips, he has put some miles on it. He took it to another shops dyno day and it made 900 rwhp on their DynoJet. Bob
https://vimeo.com/4192845
http://www.superchevy.com/features/0...cadillac-ctsv/
__________________
Old May 26, 2016 | 03:58 PM
Thanks for the reply Bob. Will definitely check these builds out when I get home.
Old May 26, 2016 | 04:07 PM
LS1Tech Sponsor
You're welcome, thanks. Bob
__________________
Old May 27, 2016 | 08:46 AM
Which bearing should I run? The clevite P or H series rod and main bearings.
Old May 27, 2016 | 08:57 AM
Going to use clevite H series bearings. Finally found some info on them.
Old May 27, 2016 | 12:58 PM
conan's Avatar
I'm running H bearings in my 383ci, no problems.
