Boosted LS7 Carnage
Old May 24, 2016 | 10:43 PM
Mrgoodwrench3's Avatar
Default Boosted LS7 Carnage
2007 C6 Z06 Corvette
Stock bottom end
BTR cam, springs, pushrods, CHE rockers
Kooks long tubes, B&B Bullet exhaust
A&A Super Charger, 8 rib conversion
WCCH CNC ported heads
ACT dual disc clutch
Boost a pump
Pulleys for 9 psi.
12 degrees of timing on the dyno and all hell broke loose!
Cylinders 5 and 7 broke the top ring lands at the 10 o-clock position. Both cylinder walls also cracked blowing coolant everywhere.
Old May 25, 2016 | 05:47 AM
yenkomike's Avatar
how many miles . looks like the ring gaps were to tight .damn shame sorry about your luck.
Old May 25, 2016 | 06:23 AM
69-chvl's Avatar
Interesting how the pistons broke in the same spot. I assume that's where the gaps were? Do you know what the gap was?
Sorry for your loss. Glad it didn't happen at speed.
Old May 25, 2016 | 06:58 AM
NoorJ's Avatar
The rings move in the bore, I highly doubt the gaps would just happen to line up in the exact same place. That is probably just the weakest part of the piston, or the area that runs hottest on the piston crown, causing knock.
OP were you running 93?
Old May 25, 2016 | 07:02 AM
svslow's Avatar
This was only on 9psi and 12 degrees?
Old May 25, 2016 | 07:05 AM
JoeNova's Avatar
Restricted User
If the ring gaps were unchanged, I would vote ring gaps as well.
Everytime I see someone break an LS7 on less power than I've made a hundred times on a junkyard engine, I have to believe I made the right choice... I couldn't afford what just happened here.
Old May 25, 2016 | 07:08 AM
ddnspider's Avatar
Any knock on the dyno run? What was the AFR during the pull?
Old May 25, 2016 | 08:03 AM
69-chvl's Avatar
I would agree with that. However, if this was a new build, maybe all the ring gaps were left in that position and then it blew up. All the Pistons and everything else looks clean which leads me to believe this is a fresh engine.
Old May 25, 2016 | 10:31 AM
truckdoug's Avatar
dang, bummer
Old May 25, 2016 | 12:54 PM
These pistons and rings are stock GM LS7. Car has 35K miles. This was not a new build. The car came to me with the A&A kit on it. Installed by another shop about 2 years ago. I sent the heads out and changed the cam and put on an 8 rib set up.
Made 5 dyno pulls. 660 HP/650TQ. No signs of any detonation. Added 1 more degree of timing. At about 5600 the tuner thought something didn't feel right so he shut it down. A few minutes later he started it back up and it blew coolant out the left side exhaust.
Old May 25, 2016 | 04:07 PM
Busa_rob's Avatar
That's textbook tight ring gap right there, not detonation.
Old May 26, 2016 | 08:32 AM
sbcgenII's Avatar
Detonation.
Old May 26, 2016 | 09:47 AM
hellbents10's Avatar
LS1Tech Sponsor
Stock bottom LS7 and boost is a gamble at best on pump gas. You can run them super fat with no timing and hope for the best is all.
Old May 28, 2016 | 06:43 AM
forcd ind's Avatar
Was the valve to piston clearance checked? on a cast piston it doesn't take but a slight touch and things go wrong
I know some guys run timing that low, but I sometimes wonder if its enough
to start the burn so you dont leave excess fuel as it compresses the mixture
We found this years ago on a gen 1 engine-I am still wrapping my head around timing on gen 3 engines, how diff they are in tuning, lol
Old May 28, 2016 | 12:38 PM
Put together a replacement engine.
New GM LS7 block
Callies Dragon Slayer crank
Callies Ultra H beam rods
Wiseco 18cc dish pistons
Clevite bearings
Durabond cam bearings
Fully balanced
Old May 28, 2016 | 02:33 PM
slocaddy's Avatar
Well that's one way to fix it lol!
Old May 30, 2016 | 03:52 AM
stevieturbo's Avatar
Is it still not a risk with the LS7 block ? Would they not have very thin liners compared to some other options ?
Old May 30, 2016 | 08:22 AM
sbcgenII's Avatar
Maybe he installed some sleeves???
Old May 30, 2016 | 08:29 AM
Maybe he did...but he doesnt say he did.
Old May 30, 2016 | 09:03 AM
Krom's Avatar
wouldn't it have been cheaper, to build a stronger engine, by having the existing block sleeved???
