4" Downpipe questions??
Old Jun 7, 2016 | 03:35 PM
KyleLanter's Avatar
Default 4" Downpipe questions??
I have a huron speed v2 t4 ac kit and was wondering is anyone could recommend a 4" downpipe that would run through the k member? I am wanting to retain an exhaust and not run through the bumper. The downpipe that comes with the kit is a 3" and I will be running a s480 which needs a 4". Any help would be great.
Thanks everyone
Old Jun 7, 2016 | 04:50 PM
jrpimp00's Avatar
Make your own, thats what I did
Old Jun 7, 2016 | 05:23 PM
thompson's Avatar
You will likely have to ovalize the pipe through the K member, I don't think it is possible to get through it without doing that. We have the same kit on one of our cars here at the shop and went down and back with the down pipe and did a bit of a slant cut on the bottom to exit under the car, Really not too loud either.
Thank you,
Kyle
Thompson Motorsports
Old Jun 7, 2016 | 06:25 PM
jrpimp00's Avatar
Guess I should add im running a BMR turbo K-member
Old Jun 7, 2016 | 10:08 PM
KyleLanter's Avatar
Jrpimp I am running a BMR turbo k also. Did you retain ac? And did you exit the drivers side on back?
Thompson would you happen to have pictures of the downpipe? I am trying to figure out which route I want to go.
Thanks guys for the help.
Old Jun 8, 2016 | 01:48 AM
SteenH's Avatar
I made two of these motor mounts retaining the stock K. One 4" U bend piece from summit was all the piping I needed to make it out past my Huron 3" DP
With your K member you should have it much easier. Just take your time and you'll feel very accomplished when you're done, especially when you have a nice quiet car with that 4" stove pipe that flows like a mother.
I'll try and post photos of my piping when I get home in a few days.
Old Jun 8, 2016 | 09:20 AM
jrpimp00's Avatar
I got rid of the AC well before hand. I have the V1 kit and welded on an adapter to run a T6. Exhaust goes through where the ac was, snakes around the outside of the motor mount pedal stool and then comes out at the starter then about 2ft of 4" tubing to my cutout then ran to the back through a 3" magnaflow.
Old Jun 8, 2016 | 01:14 PM
thompson's Avatar
I will get a few pictures for you. It looks like you do have the room to go through with the tubular set up and no AC.
Old Jun 8, 2016 | 08:31 PM
KyleLanter's Avatar
Awesome thank you guys for the help and experience. It's helping me narrow down the path I want to take.
Old Jun 9, 2016 | 12:19 AM
NBM-LS1's Avatar
It's tight but she will make it.
Old Jun 9, 2016 | 09:36 AM
V-10 Killer's Avatar
I'm not sure on the T4 v2.0, but I have the T6 setup. I cut and turned the 4" down with a boost actuated cutout. Then I tied a 3" pipe into it and ran it back to my magnaflow exhaust.
Here's a pic:
Old Jun 9, 2016 | 03:15 PM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
That k-member allows for up to a 5" DP. Here are some pictures i have to give you ideas. I don't know of a readily available pre-fab option so you will likely have to build one, or have a local shop fab it. But this should give you some ideas
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old Jun 9, 2016 | 08:59 PM
KyleLanter's Avatar
Eric, thanks for the pictures that makes me feel a lot better about the room I will have. Glad I went with a BMR turbo k!
Old Jun 9, 2016 | 10:23 PM
fccs's Avatar
I have the same kit as you (getting tuned end of month) and I was in the same boat. Wound up just sticking with 3inch and am going to just cutout dump it. I have no idea how people fit 4inch there lol
Old Jun 10, 2016 | 10:20 AM
BMR Sales2's Avatar
Bear in mind, the ones I posted have a manual rack, the stock rack will offer slightly less clearance in that area, but not a huge difference. Still plenty of room to work with.
__________________
Glenn ***
Sales Tech
813.986.9302
