Need some help with boosted lq4
Old Jul 4, 2016 | 01:48 AM
O90110's Avatar
Default Need some help with boosted lq4
As the title says I'm looking for some help with my blow through LQ4. Once boost starts coming in and raving around 3-3.5k the engine breaks up and restricts me from reving any higher. 2001 LQ4 truck block, stock bottom end(new bearings and rings) stage 2 tick performance cam, csu blow through 750, Victor jr intake, Daytona sensors box, 76mm turbo(12psi) non I/c ran on e85. Plugs are BR7EF's gapped at .020 fuel pressure 5.5-6psi(with boost reference regulator) timing is just a base so far at 30deg in vacuum then dropping 1.5deg for every 1psi of boost. I'm totally new to the boosted lifestyle and any advise/come to are greatly appreciated. Thank you in advance and any other info needed just ask
Old Jul 4, 2016 | 11:39 AM
O90110's Avatar
Bump.. anyone???:
Old Jul 4, 2016 | 01:07 PM
MY_2K_Z's Avatar
Valve springs
Old Jul 4, 2016 | 04:08 PM
crowstyle's Avatar
what map sensor you have.
Old Jul 4, 2016 | 04:46 PM
O90110's Avatar
Valve springs are brand new with cam and it's a 2 bar map. Part number 12615136. Did some searching on this forum and found this works out of a cobalt Ss I believe. Truck breaks up under boost only for sure. I can ease the throttle without boost and keep it going but once it starts building it just breaks up
Old Jul 4, 2016 | 07:40 PM
sbcgenII's Avatar
So at 1 psi of boost your are at 28.5*? I don't think my stock timing table had that much in it anywhere at wot. I would pull out 10* for a start. How much boost are you making at 3/3.5k? What is the AFR? Does it break up as soon as it hits boost?
Old Jul 4, 2016 | 07:41 PM
chiaj144's Avatar
What's the wideband say?
Old Jul 4, 2016 | 09:26 PM
O90110's Avatar
Yes thats correct on the timing. I'm totally new with the timing table and boost so I was only going off of what I read. And it breaks up as soon as it hits boost. Wide band goes 9.5(gas scale)
Old Jul 5, 2016 | 12:01 AM
sbcgenII's Avatar
Your wide band is probably maxed and you are super rich. Was the carb setup for your combo?
Old Jul 5, 2016 | 11:21 AM
O90110's Avatar
Yes, Kevin at csu built it for what I'm doing.
