Head pulley size.
Old Jul 18, 2016 | 07:37 AM
tvanlant's Avatar
What diameter is your crank pulley? Engine RPM? What engine?
It seems like you're spinning the blower awfully hard just to make 17 lbs. I run a 5.25" blower pulley and make 18 lbs.
Old Jul 18, 2016 | 08:32 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Originally Posted by BLNLS1/RX7
Went up to Leesburg IN. and had Justin dyno and data log my car since Brent is still recovering from his last surgery in June.Made 5 pulls and it appears that maybe the belt is slipping and was losing a couple lbs. of boost.The car was also running very rich.Made some adjustments and now I need to get to the track with it.How is your Vega coming along Bob?
I didn't know Brent had another surgery, is he doing okay?
I got an Gen V LT1 that is going into the Vega, I just haven't had enough time to do much with it yet. Tony got back from Afghanistan and bought a wrecked Wrangler JK. We took the body off swapped frames, and installed an LS iron block in it. Less than six months after Tony was back he headed back to Afghanistan. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Jul 18, 2016 | 10:30 AM
BLNLS1/RX7's Avatar
It is a 6.0lt. iron block bored .60 over.The head pulley is 3.85.
Old Jul 18, 2016 | 10:34 AM
BLNLS1/RX7's Avatar
He had to go back in again ( 3rd ) for repairs from his original surgery.He will be on limited work for awhile until he gets healed up.Well I guess I wont see your Vega at the track this year.Did Tony re-enlist?
Old Jul 18, 2016 | 10:51 AM
tvanlant's Avatar
Yeah, we need to know blower speed. Crank pulley diameter, engine RPM?
Old Jul 18, 2016 | 10:57 AM
BLNLS1/RX7's Avatar
The F1-R is rated at 68,000 with max. boost of 38lb.Crank pulley is 7.625.Engine RPM was 6700 on this session.Do not know what the blower speed was.
Old Jul 18, 2016 | 11:10 AM
tvanlant's Avatar
Blower speed = RPM X CRANK PULLEY DIA. / BLOWER PULLEY DIA X STEP UP RATIO
For yours: 6700 X 7.625 / 3.85 X 5.40 = 71,655 rpm.
You are spinning the blower way too fast. And you have a huge problem elsewhere. The F1R will make a ton of boost at max RPM. I'm spinning my F1R to 57,600 rpm and making 18 lbs.
Old Jul 18, 2016 | 11:27 AM
BLNLS1/RX7's Avatar
Don't you have to factor in the tire size?
Old Jul 18, 2016 | 11:37 AM
LS1Tech Sponsor
Man, that's too bad, I feel bad for Brent!
Tony's over there as a contractor, it's his third or fourth time as a contractor. Bob
__________________
Old Jul 18, 2016 | 11:38 AM
LS1Tech Sponsor
Nope, tire size doesn't affect impeller rpm Steve. Bob
__________________
Old Jul 18, 2016 | 12:46 PM
tvanlant's Avatar
If you share more information about your setup, we can help you figure it out.
I would not run the car any more until you figure it out or you will start breaking stuff.
1st thing - put your 4.00" pulley back on (or a 4.13 or 4.25 if you have one). With the blower at max rpm, it should make around 30 psi, depending on what heads, cam, intake etc.
What intercooler do you have? Pictures of it?
What do you have for an inlet?
Exhaust?
Old Jul 18, 2016 | 01:00 PM
  #32
BLNLS1/RX7's Avatar
Exhaust?
intercooler is 31 X 12 X 4 and is new.The heads are TEA Stage 1 The intake is a LS2 with a 92 MM throttle body.There was no room for a filter on blower.Lingenfelter blower cam.The header were made for the application.
Old Jul 18, 2016 | 01:26 PM
  #33
tvanlant's Avatar
picture or link to the intercooler?
Pictures of the engine bay?
Old Jul 18, 2016 | 01:53 PM
  #34
BLNLS1/RX7's Avatar
Unable to locate paperwork on the intercooler but it was from E-Bay and I think it was around $200. Can take pictures later today.
Old Jul 18, 2016 | 02:18 PM
  #35
LS1Tech Sponsor
The GTO crank pulley is 7.00" in diameter. Bob
__________________
Old Jul 18, 2016 | 02:33 PM
  #36
LS1Tech Sponsor
This picture of Steve's car was most likely after we had installed the D-1SC at the old EPP shop. Bob
__________________
Old Jul 18, 2016 | 02:34 PM
  #37
BLNLS1/RX7's Avatar
When I went to the F!-R from the D1 I had to switch out the crank pulley to a 7.625 to be able to run the 12 rib belt.
Old Jul 18, 2016 | 02:35 PM
  #38
LS1Tech Sponsor
Ah, that makes sense. Bob
__________________
Old Jul 18, 2016 | 02:38 PM
  #39
BLNLS1/RX7's Avatar
Intercooler looking up from garage floor.
Old Jul 18, 2016 | 02:43 PM
  #40
BLNLS1/RX7's Avatar
Thanks Bob. Yea this is the old set-up with the D1.
