spark blow out problems
widebands only read correctly when combustion happens correctly, as said, they dont always tell you what you think...at least not directly.
21-22psi, .018 gap on ngk 1049s. Even got the random knock he said. E85, 15.5-16.5 timing. 180 eng temps, and AITs below 120.
5.7L 9.5 compression S480/92 1.0 t4
I was wondering if it's 112k OEM truck coils are tired. Thinking about trying those 15% hotter Accel coils. Wish hey wasn't yellow, they ugggly.
How tight can you go?
My setup put down 990HP through a 4l80 at 22-23psi. I feel like 1200ish crank HP and a one range colder then stock plug is pretty bad advice. Open to other suggestions though, thanks guys.
A wide band measures O2 levels in the exhaust.
When a cylinder misfires because it is overfueled it raises the level of O2 in the exhaust.
To those who directly interpolate O2 output into AFR are mislead, instead of seeing it for what it is.
This is why a Dyno with a 3 gas analyzer can be helpfull.
The false lean (elevated levels) from the O2 sensor would be accompanied by reduced CO and an HC spike in the above scenario.
If it is smoking like a diesel it might be rich.....
