Help navigating turbo maze for LQ4
Old Jul 7, 2016 | 04:35 PM
I R Gunnr's Avatar
Default Help navigating turbo maze for LQ4
I am looking to finally boost my LQ4 in my 2500HD truck. Being that my vehicle weighs 6500 lbs, I am struggling to make a decision on a turbo. The motor has 150K on it, so I don't want to punish it too hard, but I do understand it's due for a refurbished pretty soon. Currently looking at a TC 70 or TC 76. I am getting my hot section and downpipe from RM Performance, just need to decide on a turbo. I know most folks go supercharged on a truck, but the efficiency and engineering of a turbo system is more appealing to me. I enjoy driving a turbo vehicle and feeling that umph when it starts to boost, it's also a good way to terrorize my wife.
Goals
1. Make 450ish HP at wheels
2. Boost very low in RPM range
3. Maintain daily driver status
4. Not melt the motor when I tow, which is maybe once a year.
5. Keep the boost at ~7 PSI to nurse my motor into retirement.
I know I am looking for a small turbo, so it will spool quickly, but just don't want to go too small and choke the exhaust.
Would super appreciate any direction or help.
Old Jul 7, 2016 | 06:22 PM
93camaro_zzz's Avatar
I had this same idea to do to my 2500HD LQ4. I love the trucks! 4L80e. 14 bolt rear. The trucks are very solid. Mine was a crew cab short bed, so I figured with the mile long steel 2 piece driveshaft, and completely bone stock, the truck probably made around 225whp. Best guess. What I was wanting to do, was do a simple and cheap turbo setup on it, and try to target 450whp. Most people stop me there and say, "What? only 450whp? But every LS vehicle that has a turbo on it instantly makes 1000?"
But think about it like this. You are literally doubling the power output of the truck. It will definitely be noticeable. Your towing is going to be a cakewalk with double the power and probably more than double the torque. And then with 450whp, you could imagine that the whole setup should be very reliable indeed. Plus, like is the nature of turbos, when you do become addicted to it, and want more power, it is just a manual boost controller or a turbo swap away from making any amount of power you would like.
So with that being said, this is the turbo I was going to look into. Should spool super fast, and should make the 450whp goal easy enough.
http://www.vsracing.net/catalog/prod...oducts_id=1323
Good luck.
Old Jul 7, 2016 | 07:15 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
The 67mm Garrett turbos that were an "upgrade" on the kits Livernois used to sell are perfectly sized for what you want to do. That size turbo will allow the LQ4 to brake boost a few psi at launch, but not completely choke the fun out of your top end. With transmission upgrades, several full weight Escalades were running in the 12's 1/4 mile. I know firsthand from helping install and then tuning one of those kits with that turbo on my neighbors escalade. The instant available torque combined with AWD ripped the tailshaft out of multiple built 4l60's before upgrading to a 4l80. With the stock fuel pump and 42" injectors we ran out of fuel before the turbo choked out. I set the transmission maximum shift rpm to just under the point where fuel pressure dropped off until the fuel supply could be upgraded. The truck is still driving around like that 10 years later. BTW, don't count on 150k miles being anywhere near needing to be refurbished. I waited until 120K miles to whipple supercharge my Silverado, and it is still fine at almost 330k miles.
Old Jul 7, 2016 | 08:57 PM
yenkomike's Avatar
I have done a on3 kit on a 2500 hd. there are a few things that are different. the front bumper brackets need a lot of cutting to make the intercooler fit. we used a 76/65 turbo and ran it fairly hard. the torque converter will need swapped if you go to 10 pounds or so boost. makes the truck pull like a dmax.
Old Jul 7, 2016 | 09:34 PM
I R Gunnr's Avatar
Good luck.
I bought the truck new back in 2005, didn't have the money for the diesel at the time so went with the 6.0L. It's been great, I've fallen in love with the LS series motors, so durable and unlimited ability to upgrade. Your thought process is the same as mine, make reasonable horsepower, have fun, but have a truck that will continue to last. Thanks for the input, that looks like a good size turbo, I'm just still a little leery of the on3 and VS racing stuff, being that they are 1/2 the price of everyone else. Might take the plunge , definitely work a second look.
Originally Posted by gametech
The 67mm Garrett turbos that were an "upgrade" on the kits Livernois used to sell are perfectly sized for what you want to do.... The truck is still driving around like that 10 years later. BTW, don't count on 150k miles being anywhere near needing to be refurbished. I waited until 120K miles to whipple supercharge my Silverado, and it is still fine at almost 330k miles.
Looking at the Garrett website right now, thanks for the tip. HUGE thanks for letting me know I made the right choice with my motor. I almost pulled it out for a full rebuild before I did a leak down test and found everything to be good to go. Decided to spend the money on a turbo kit instead. Makes me very happy to hear someone getting 330K out of a motor with forced induction. Very good stuff.
I actually have a new trans being built by Jake's Performance right now. Rated up to 750 Hp, I'm gonna give them a call to confirm the converter, but it should be up to the challenge. Do you know how the reliability on the on3 kit was? My only hesitation with on3 is the low price point and some of the horror stories I've read online. Where was the intercooler mounted? Down below the radiator or right in front of it?
This site rocks, please keep it coming.
Old Jul 7, 2016 | 09:37 PM
I R Gunnr's Avatar
What about something like this?
GT4094R
Compressor ind diameter 67.80
Compressor exd diameter 94.00
Turbine diameter 77.00
HP 450-800
Displacement 2.0-6.0
A/R 0.85
EDIT: That sucker is $2000!!! The search continues...
Old Jul 7, 2016 | 09:50 PM
gametech's Avatar
I gave you a firsthand real world account of 1 specific turbo because I am not an expert on turbo specs. There are so many choices in configuration between hot and cold side wheel sizes, covers, etc., that I could not give a decent answer for any turbo I haven't used. I can barely read a compressor map, and I still need a calculator to figure out what it means for a given combo. Something you should know, however, is that if you use a premade kit, you need to stick with the size turbo the kit was made for. Changing turbo size can mean downpipe and other fitment issues that require a degree of fabrication that negate any upside to buying a prefabbed kit.
Old Jul 11, 2016 | 11:28 AM
Yeah, I hear your concern on that part. My thinking is that if it doesn indeed fail, then it was only a $300 mistake. But looking around these forums, it seems people are geting some decent reliability out of them.
Old Jul 11, 2016 | 01:09 PM
Forcefed86's Avatar
The $400 78/75 VS racing unit is a very capable "small frame" turbo that's easy to package. (smaller than the GT45) I'd go that route before putting a TC 70-76 on it.
Old Jul 12, 2016 | 12:32 PM
FourG63 97GST's Avatar
I ran a precision T4 6775 .96 on my 5.7 and loved it. the responsiveness was pretty close to N/Aish. I'm about to switch it to my 6.0 to see how she likes it.
but it'll start making boost around 1800rpms, 7psi by 2800. torque curve made it fun to drive. torque was 400ftlbs @2500, 500-590ftlbs from 3500-6500rpms.
Old Jul 12, 2016 | 03:19 PM
Forcefed86's Avatar
How much boost for those numbers? That on the LS2? Was the turbo tapped at that point? Sounds like a fun setup!
Old Jul 13, 2016 | 01:00 AM
that's on the LS6 longblock, E85, 7psi. 227/227 cam, I was street tuned after that so i dont know what it did on 13psi. will be copying and pasting on the LS2 here soon enough.
Old Jul 14, 2016 | 11:53 AM
I R Gunnr's Avatar
That sounds like exactly what I'm looking for. Thanks for posting. Can anyone comment if the slightly bigger displacement of the 6.0L would have a big impact on the manners of this same turbo? I know it will have more airflow, but don't know if it's enough to cause a problem.
Old Jul 14, 2016 | 05:11 PM
Project GatTagO's Avatar
GT4094R
HP 450-800
A/R 0.85
Check out the Borg Warner S300SXE turbos. They are available in various sizes and are less expensive than the GT4094R...
Andrew
