Is a GT80 going to cut it with a 383?
Forged 383 short block w/ 9:1
Trickflow 220 heads
FAST 92/92
Custom grind turbo cam
Custom Fuel System
80lb injectors
Built T56
9" w/ 3.73
Suggestions and sharp shooters recommended.
Thanks in advance.
97mm Turbine Wheel
1.08AR
I know that is is a bit bigger, but it would give me room to grow later on down the road. The engine is going to be brand new, so I don't know that really matters right now. I really need to just call Dr Turbo and get his recommendation. First world problems.
What is the race weight? I'm well into the 8's with a much smaller turbo (T4 s476 with 87/96 wheel) 370 cubes, 3100lbs and only 18ish lbs of boost. Your heads and stroked engine will flow more than a 370" LS like mine, but I still think you'd have more than enough turbo with the GT80.
Trickflow 220 heads
FAST 92/92
Custom Fuel System
80lb injectors
Built T56
9" w/ 3.73
Thanks in advance.
