Want to shoot some N20
Old Jun 18, 2004 | 02:24 PM
Ed Blown Vert's Avatar
Default Want to shoot some N20
What can I get away with at the track? 50? 75?
Old Jun 18, 2004 | 03:05 PM
smokinHawk's Avatar
Start out small then increase. keep an eye on everything to make sure your ok
Old Jun 18, 2004 | 03:09 PM
BIGBOS's Avatar
You still running 11:1 w/the blower?
Old Jun 18, 2004 | 03:16 PM
kp's Avatar
kp
I have 15 passes now with the 50 shot, I'm shutting it off at 5900rpm since my MAF wont make if I spray it all the way to 6500 where I shift. With a wet kit its your fuel system that will limit you but a 50 will put a smile on your face. I have less detonation with the nitrous then without it on pump gas (93). I got .45 off and +4mph in the 1/4 using it on a 80 degree day, it works well..
Old Jun 18, 2004 | 05:05 PM
I was just worried about making too much Torque.
Yes still on 11:1. Heads are not here yet.
It will be a wet shot. Running on the rich side.
And that is the reason for using it at the track. Keep everything cool and detonation free.
Old Jun 19, 2004 | 08:28 AM
DaveSchott's Avatar
Let us know how it works out. I'm finishing up a alky injection system to do the same. Though it would be simpler and safer than a low dose of NOS but in the end it probably is only a little safer.
Old Jun 22, 2004 | 02:59 PM
BigPlanTransAm's Avatar
why not use alky for the fuel side since its a wet shot? th ebest of both worlds
Old Jun 22, 2004 | 03:13 PM
I was actually thinking of using the second stage of my MAF kit for alky.
But I already have N20 so thought I would try it.
