Sloppy mechanics how to: broken exhaust manifold bolt removal *update 8/1/16
Old 04-21-2013, 10:14 PM
Moderator
denmah's Avatar
Default Sloppy mechanics how to: broken exhaust manifold bolt removal *update 8/1/16
seems like the photos i had uploaded died so here is video!**
i have made threads and photos but recently had a friend drop off some heads that were pretty bad and showed in real time how i deal with them
pulled a ton of them in less than 20 minutes that he could not get out
just wanted to show people how it works again
Old 04-21-2013, 10:50 PM
dmeyer's Avatar
I have one of those problem now. Just might have to try this out.
Old 04-22-2013, 05:45 AM
JAX04's Avatar
Lol, saw them do this on Fast n Loud and thought id def try this if it was every a problem
Old 04-22-2013, 05:56 AM
pwrtrip75's Avatar
Go one step farther and weld a nut on it and use a wrench to take it out. Also tapping it with a hammer will free the threads up some...sometimes.
But if you heat the bolt up before you try loosening it.....ive never broke one.
Old 04-22-2013, 07:57 AM
Twin turbo c5's Avatar
I have two broke off in my turbo 6.0 in my fairmont . I just left them. my manifold aren't leaking yet. but i'll remember that. Damn junkyard motors.
Old 04-22-2013, 08:00 AM
Moderator
denmah's Avatar
you cant weld a nut on it, when its broken off inside the head
Old 04-22-2013, 09:26 AM
dmeyer's Avatar
Will it mess up the aluminum if I hit it with the weld?
Old 04-22-2013, 09:29 AM
Moderator
denmah's Avatar
nope it does not stick to the alum you can goober it in there pretty good, i have yet to kill some threads,
drillbit on the other hand i ruin the cyl head lol
Old 04-22-2013, 09:34 AM
dmeyer's Avatar
Cool I will try it tonight.
Old 04-22-2013, 10:36 AM
HRHohio's Avatar
Cool info on it not messing up the heads. Good to know.
As for the nut, maybe if you got the goober long enough to stick out of the head, you could tack a nut on the end of the booger. That way you could get a socket on it instead of vice grips. Maybe that's what he meant. Either way, good info. A friend of mine had one break off the head of the bolt, still had about 1/2 inch of bolt sticking out. We heated the bolt with a propane torch and used vice grips. (No welder handy). Amazing how fast the head dissipates the heat. We had to heat it about 6 times. Each time the bolt would get tight again after about 30 seconds of turning.
Old 04-22-2013, 10:44 AM
hbcruiser's Avatar
I just got done drilling mine but this looks like a good tip
Old 04-22-2013, 12:16 PM
pwrtrip75's Avatar
if you can get on it with vice grips you can... do what you did, build it up then weld a nut on. i actually weld a washer on, then weld the nut to the washer.
Old 04-22-2013, 12:31 PM
Blackpanther99's Avatar
Smart move.
Old 04-22-2013, 01:07 PM
Moderator
denmah's Avatar
too much work and a waste of a nut and washer lol
Old 04-22-2013, 06:13 PM
dmeyer's Avatar
I just tried it and it worked as promised !! I tried the nut but it the process , Missed the nut and managed to run the wire into my glove onto my index finger..... F the nut and gubber it on.
Old 04-22-2013, 09:05 PM
tired2valve's Avatar
I have two of these. Both front ones. But on iron heads
Old 04-22-2013, 09:07 PM
gofastwclass's Avatar
It can be done but a TIG is better for that job. I've done it to the bolts on cast exhaust manifolds.
Old 04-22-2013, 09:11 PM
True. I got fed up with it after breaking 2 titanium drill bits in one side and a ez out on the other. Threw em on there and haven't had a problem yet. (Knock on wood)
Old 04-22-2013, 09:17 PM
tiznodd's Avatar
Denmah,
Thanks for posting this up. I did the drill bit/ez-out thing last time, but that can go wrong quickly. Once a hardened bit breaks off inside the stud, you're done. I've got a 317 I'll be trying this on soon. Thanks again!
Old 04-22-2013, 09:57 PM
Igloo's Avatar
Awsome denmah ! I do almost the same thing just with an arc welder ,lol.
Quick Reply: Sloppy mechanics how to: broken exhaust manifold bolt removal *update 8/1/16
