Salt water Application
Old Aug 18, 2016 | 08:17 PM
oscs's Avatar
Default Salt water Application
Some of you are aware that I sold the Z and am moving overseas (Trinidad) I have sourced an iron 5.3 and will be taking it with me. I haven't decided if I'm going to toss it in a boat with a few turbos or a RHD project when I get there.
With that said has anyone seen/heard or have experience with an iron block inboard? I know the aluminum block is a no no but haven't heard anything in regards to salt water use with the iron block. A buddy was telling me it requires special gaskets and what not. I don't know anything about it.
I'm not apposed to closed loop cooling system but it sure would be convenient to draw the cold sea water in to cool the motor down.
Any and all ideas welcome!
Old Aug 18, 2016 | 08:45 PM
redss82's Avatar
heat exchanger
Old Aug 18, 2016 | 08:51 PM
oscs's Avatar
Originally Posted by redss82
heat exchanger
What about it
Old Aug 18, 2016 | 09:13 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
You use a normal freshwater/coolant type cooling system, but cool the heat exchanger with seawater. Everything about the internal motor can stay just like a car engine, but with unlimited sea cooling.
Old Aug 18, 2016 | 09:19 PM
oscs's Avatar
Right... I get the advantages of an A2W setup, this isn't my first rodeo. I'm curious about what needs to happen to the iron block to get it sea worthy. Or if it's even worth it to use sea water vs. closed loop fresh water.
Old Aug 18, 2016 | 09:43 PM
Project GatTagO's Avatar
It wouldn't be A2W, it would be W2W. Instead of looking the engine with a radiator A2W, you would look the engine with a W2W heat exchanger. The water circulating through the engine would be your typical antifreeze, or just non-salt water, but instead of using air you would use salt water to take away the heat...
Andrew
Old Aug 18, 2016 | 09:55 PM
MY_2K_Z's Avatar
I don't think you understood him. He's not talking about the turbo or supercharger intercoolers he's talking about the engine cooling system.
Old Aug 18, 2016 | 10:00 PM
Yes....engine cooling set-up...see my post above...
Andrew
Old Aug 19, 2016 | 06:08 AM
BanditDave's Avatar
You do not want to use salt water in your engine. Period. Sea water is ~3.2% salt by volume and what it will do to the inside of your engine is down right heroic. You might be able to get away with a fresh water raw water system but even duplex stainless struggles to survive in salt. Scaling inside the water jackets of a raw water system becomes expensive to fix. Replacing a heat exchanger is much cheaper by comparison.
Water to water HX is def the way to go...you have an unlimited sink like the poster above mentioned and generally cheap parts to replace.
Safe travels my friend, loved your Z...sad to see it go!
Old Aug 19, 2016 | 06:13 AM
RixTrix's Avatar
Keel cooler
No salt water in my motor.....
Old Aug 19, 2016 | 06:49 AM
forcd ind's Avatar
Over the years I have seen some destroyed gen 1's and big blocks because of salt water-even if you flush it after every use it will still get eat up
If possible, I would do a closed cooling system-I have seen some pretty rusted on the outside LS blocks, could only imagine what salt would do to the inside-the gen 1's and BB's always got brass freeze plugs, they were always the first thing to go-if it was a known boat engine, some got a treatment into all the water passages, but that prob doesn't last to long.
Bummer about the Z, I liked that car
Old Aug 19, 2016 | 07:34 AM
oscs's Avatar
Andrew
Well that makes a hell of a lot more sense. I was like "what are these people talking about" lol
Old Aug 19, 2016 | 07:36 AM
oscs's Avatar
These are the answers I was looking for. Thanks guys!
Old Aug 19, 2016 | 07:41 AM
Black89Z51's Avatar
You're also going to need stainless steel valves. The exhaust manifolds are cooled by water and you don't want that to get on normal valves. I've helped some friends with boat engines (34' Scarab with twin 454s, 35' Cigarette with twin 542s). Both of those boats run heat exhangers.
Old Aug 19, 2016 | 07:48 AM
Nali6.2's Avatar
my buddie had a Malibu ski boat and it has an a ls7 in it and its on a complete closed system.
Old Aug 19, 2016 | 07:51 AM
oscs's Avatar
I thought the water was more for noise control instead of cooling?
Old Aug 19, 2016 | 06:26 PM
Black89Z51's Avatar
It's to keep the engine bay and manifold temps down as you know they can get hot and could cause a fire which is a huge concern on a boat that can trap explosive fumes under the "hood". That's why typically any boat you vent the engine bay for a few minutes prior to starting it up to ensure you don't have an explosion. Also air cleaners are spark arresting material (stainless mesh) and not paper or K&N. There's a lot of fire preventative measures on boats.
Old Aug 19, 2016 | 09:47 PM
oscs's Avatar
I see. Thanks for the insight. Kind of a funny thing seeing as they float in water.
Old Aug 19, 2016 | 10:00 PM
gametech's Avatar
I always thought that too, but if my car catches fire I don't get eaten by sharks after drowning.
Old Aug 20, 2016 | 06:48 AM
oscs's Avatar
lol solid point
