Anyone running a LLSR/Turbo combo?
I've had one in mine for almost 2 years now albeit with a mild profile. Although I did just order a slightly bigger cam just a few days ago although wont be changing it until over the winter.
Do you feel the performance & durability difference is worth the cost offset in most circumstances?
Current profile is around 228/230 on 116 with a tad under 600thou lift, bumping that up by around 10deg or so and a little more lift.
Profile was kept mild initially because I want a super smooth idle and have yearly emissions tests to pass, so wasnt taking any risks as far as overlap etc go, although it passes these with ease hence pushing it up a bit further soon.
I originally wanted a cam that would be happy at 7-7500rpm for standing mile stuff etc, although I think forcing that milder profile didnt help me with that goal. The new profile should resolve that.
No doubt there are hydraulic cams that will do that too....I just wanted a solid roller, it seems like the more sensible option to me from a mechanical point of view.
I had no performance or durability issues with hydraulic...and nor have I had with the LLSR. I didnt change for those reasons*....I changed largely because I wanted to. Cost wasnt a big deal for me either, as I wanted to change the YT rockers I'd been using for several years anyway. I ended up with the 1.7 Jesels
*other than once a few years ago when I had some oil pressure problems...this very clearly was affecting the hydraulic setup and valve timing was affected. Obviously the oil pressure problem was the core problem there....either way, with a solid roller oil pressure will never effect the valve operation/timing etc.
So playing safe was the best option.
It just ended up far safer than expected lol.
And I'm sure we all throw more money at our cars than is necessary !
I've never dealt with these new low lash cams. I've ran solid flats & rollers before but it was before the time of the lower lash stuff.
I appreciate the input.
Mind me asking the valve curtain timing?
