Thoughts on turbo condition? (pic)
Old Sep 5, 2016 | 03:59 PM
Purple95Z28's Avatar
Default Thoughts on turbo condition? (pic)
What are your thoughts on the condition of the turbine wheel (and turbo in general) on this 6062? To make a long story short, some exhaust housing bolts backed out and it rubbed on the inside of the housing some. I need to know if it's something that could cause issues etc or if it's totally fine. Thanks!
Old Sep 5, 2016 | 07:07 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
It is likely going to be out of balance, at the very least. If it even spools up like that it will eat bearings in short order, if it hasn't already. Is there play in the shaft?
Old Sep 5, 2016 | 07:11 PM
Game ova's Avatar
I would NOT install that thing on my motor. It's guaranteed to be out of balance, and if the bearings are shot....the turbo will send metal straight to your motor. I've been through this already, that is the turbo sending brass into the motor. See that motor on the stand in my sig?.....yea.
Old Sep 6, 2016 | 07:25 AM
rotary1307cc's Avatar
Sending brass into the motor? Wtf
Old Sep 6, 2016 | 08:07 AM
Game ova's Avatar
Brass....metal....whatever the exact material is, ended up in the bottom of my oil pan. Whether you believe it or not is irrelevant, as I've seen it first hand....live in the flesh. A bad turbo can, and WILL contaminate your oil.
Old Sep 6, 2016 | 09:45 AM
And the only thing it could possibly hurt is the oil pump
Old Sep 6, 2016 | 09:55 AM
Game ova's Avatar
Ok.
Old Sep 6, 2016 | 11:35 AM
That is why smart people block the bypass
Old Sep 6, 2016 | 02:49 PM
coltboostin's Avatar
Is it ball bearing?
If its BB, or SB and the play is within spec i'd run it all day. We used to internationally take martial off the turbines back in the day (clipping) on the small 4 banger stuff to get more turbine flow out of what we had.
