If anyone is willing to help
As far as tuning, make sure to get a 99-02 car as they can support 3 bar map sensor tuning whereas the 98 cars can only do 2 bar. 99+ cars can do flex fuel with some changes to the tune file.
Also, I like the v6 car idea but if it were me, I would go stand alone instead of stock ecu. A couple of the major steps to aftermarket ecu setups are rewiring the engine and changing gauges. If you are already doing both, then may as well get a much better ecu out of the deal than stock.
If you had planned on keeping ac, then yeah a new k member was in order. I have wondered why no one has been able to get an aftermarket ac setup to work with a truck manifold kit though. I feel like it could just based off pictures I have seen.
As far as the BCM flashing, I am not sure about that as I have never looked into swapping a v6 car before.
I only skimmed over this since i was already confused on why you want to go through all that trouble. so what is the purpose of this car and how much power are you after exactly?
ive never owned/used ms so im curious what is the added feature of ms that you MUST have over hptuners to bother with all that trouble?
I understand learning experience if thats so im all for it but since it sounds like your not going to tune it why bother?
Also the software is way better on ms than Holley.
