O2 SENSOR PLacement
Old Oct 2, 2016 | 07:49 PM
00duvall's Avatar
Default O2 SENSOR PLacement
i went to fender exit exhaust i used a 4 inch vibrant muffler.Got everything done and my wheel hits muffler at full lock.My 02 sensor is between turbo and muffler. If i move muffler closer to turbo i have to either put o2 about 4 inchs from turbo or after muffler. Which is the best way to go .
Old Oct 2, 2016 | 09:41 PM
JoeNova's Avatar
Restricted User
4" from turbo is too close in most cases.
Old Oct 2, 2016 | 09:45 PM
00duvall's Avatar
How about after muffler?
Old Oct 3, 2016 | 08:14 AM
oscs's Avatar
If it's a 4" long muffler giving 8" then it will be fine to run it after the muffler.
Old Oct 3, 2016 | 12:10 PM
00duvall's Avatar
here is what im dealing with. got to find a muffler to fit after turbo. found a magnaflow 12inch that mite work, it has a vibrant on it now at the fenderName:  1003161233_zpsaxbczqlq.jpg
Size:  345.7 KBName:  1003161233a_zpsrhigqwtn.jpg
Size:  293.0 KBName:  1003161233b_zpsvstbsx0o.jpg
Size:  318.8 KBName:  1003161234_zpsrwzmm5sq.jpg
Size:  310.6 KBName:  1003161234a_zpsuixufqfy.jpg
Old Oct 5, 2016 | 12:22 PM
GMouldy's Avatar
Why wouldn't it work right there?
Old Oct 5, 2016 | 12:43 PM
00duvall's Avatar
It does work there but i need to add another muffler and wasnt for sure if i could stick the muffler before the sensor or move sensor closer to turbo. I will be adding this muffler sum were in pipe.Its a 5x8 magnaflow.Name:  1005161337_zpswnpnr3l6.jpg
Size:  302.0 KBName:  1005161337a_zpssbfnmzd2.jpg
Old Oct 5, 2016 | 12:50 PM
00duvall's Avatar
Old Oct 5, 2016 | 02:15 PM
GMouldy's Avatar
Sorry I misread, I thought someone stated above that O2 sensor was too close already. But I see what you are trying to do now. could you not move it closer?
Old Oct 5, 2016 | 04:05 PM
JoeNova's Avatar
Restricted User
It doesn't look like you have a stock heater box.
What you need to do is trim the firewall behind the fender. The slanted part of the firewall that channels water down into the rocker panels. Cut it at the top where it meets the flat part of the firewall and down the sides. Shove it in 4 or 5 inches and weld it back up.
This is how us Nova/Camaro guys typically make room right there for a muffler without worrying about the tire hitting it.
Old Oct 5, 2016 | 05:18 PM
00duvall's Avatar
I will give it a look at. These 18x9 dont give much room to work with.
Old Oct 8, 2016 | 07:26 PM
00duvall's Avatar
Got the muffler on got to keep the vibrant on aswell. Sounds alot better.
