engine problems
Old Oct 19, 2016 | 12:58 PM
pdasterly's Avatar
Default engine problems
Whats wrong with my engine
ls2 twin turbo
Old Oct 19, 2016 | 01:03 PM
yenkomike's Avatar
going to need a lot more details to help you out. like
cam
heads
turbos
boost level
fuel
trans
just to help at all. thanks.
Old Oct 19, 2016 | 01:04 PM
JoeNova's Avatar
Restricted User
That's what my dyno looked like when I was spinning.
Did you do a MPH graph as well? My speedo was pegged at 155, dyno rollers showed I was only doing 95. Still make 575whp lol.
Old Oct 19, 2016 | 01:09 PM
pdasterly's Avatar
cam
heads
turbos
boost level
fuel
trans
thunder racing comp cams 224/224 112 lsa
ls2, afr 225 72cc
aps twin turbo(mitsubishi td06-20g)
this dyno was on 14 psi wastegate spring
91 pump gas, 80lb injectors 450lph in-tank pump
http://www.racetronix.biz/itemdesc.a...000267&eq=&Tp=
built 4l60 with precision or yank converter, cant remember which one
Old Oct 19, 2016 | 01:40 PM
svslow's Avatar
Those turbos are tiny. Is that a single gear pull?
Old Oct 19, 2016 | 01:41 PM
yenkomike's Avatar
what valve springs in it.
how much timing?
getting any knock retard?
Old Oct 19, 2016 | 02:33 PM
pdasterly's Avatar
how much timing?
factory afr springs(they have red paint on them)
16 degrees of timing, tuner says 18-19 didnt gain much
Old Oct 19, 2016 | 02:35 PM
pdasterly's Avatar
turbos are tiny but i have the lowest rwhp aps turbo kit ive ever seen
Old Oct 19, 2016 | 03:34 PM
pdasterly's Avatar
i think heads are too big, cr too low. 8.5:1
Old Oct 19, 2016 | 03:50 PM
yenkomike's Avatar
im not saying its the issue but 14 psi and 16* timing is fairly aggressive for 91 pumpgas. that is unless your iat's are very cool. id say drop timing and see if it likes it you might be getting some detonation.
I lot of guys have gotten away with more but not every combo is the same.
Old Oct 19, 2016 | 04:03 PM
pdasterly's Avatar
iat's are great, has custom built intercooler with 6" core
Old Oct 19, 2016 | 10:09 PM
Johnv's Avatar
Valve float, high back pressure from those small turbos can cause this if you dont have a heavy enough valve spring, also check plug gaps are tight , around 20" thou
Old Oct 19, 2016 | 10:16 PM
kingtal0n's Avatar
what boost controller? It looks like you hit the boost warning/control setting on a profec-B spec-II (or similar) dropping boost suddenly to some preset level.
usually, use SMOOTHING=0 for diagnosis. The "5" setting is for showing off the curve, it may mask issues with the engine.
Also an AF curve would be nice. but overall it just looks to be regulated, purposefully, you kind of see a little spike right before it occurs, which further emphasis on the control aspect.
Old Oct 19, 2016 | 10:25 PM
pdasterly's Avatar
afr red springs, plugs are at .022
Old Oct 19, 2016 | 10:26 PM
pdasterly's Avatar
I have eboost 2 but tuner uses mbc
Old Oct 20, 2016 | 11:47 AM
ls3fox's Avatar
7 Second Club
looks like valve float
Old Oct 20, 2016 | 12:02 PM
pdasterly's Avatar
these are the springs
http://www.airflowresearch.com/afr-8...raulic-roller/
Old Oct 21, 2016 | 06:39 PM
kingtal0n's Avatar
with a float I would expect some kind of jagged/ragged edge along the curve, which is why you need to look at it with smoothing=0.
Old Oct 22, 2016 | 07:07 AM
stevieturbo's Avatar
Post boost curve, post AFR curve.
And is this repeatable on the dyno...and does the car exhibit the same behaviour on the road, and in every gear ?
and the CR is not a problem.
Old Oct 24, 2016 | 01:31 PM
pdasterly's Avatar
pic with red/orange plot chart, they tried more timing and knock sensor started pulling timing.
smoothing set to 0 on both
