on3 78/75 5.3 new build track times.
we decided my buddys 5.3 turbo truck was never going to run the numbers we wanted so we put the engine in his 75 Camaro to get the feel for just how well these 5.3 turbos run.
the car is a heavy big tire car with a 3.73 gear spool 31 by 14 slick.400 trans and 3800 stall. car is 3550 with him in it.
2005 5.3 rings gapped , isky triple 12 cam degreed to Jarret's specs, stock heads , truck intake , 80# injectors , microsquirt custom hot side by me as the on3 **** does not fit the car and cracks every outher day. 2.5
on3 78 /75 turbo 3" downpipe no muffler as it got ripped off loading on the trailer
best run of day
1.37 60' 4000 rpm launch control launch
6.05 @114 mph 1/8 mile
9.44 @ 140 mph.
20.3 psi boost
15 degrees timing
e85 10.8 afr gas scale .
that 78/75 turbo really gets it done. hard to use anything else in a car running high nines or slower
best run of day
9.44 @ 140 mph.
20.3 psi boost
15 degrees timing
best run of day
9.44 @ 140 mph.
20.3 psi boost
15 degrees timing
best run of day
9.44 @ 140 mph.
20.3 psi boost
15 degrees timing
Was this up at Lapeer? How strict are they on the rules? I have been going down to Milan to run, but Lapeer is about the same distance from my house. Milan has been rather lax on the rules the few times I have been there.
yes it is a microsquirt .im not positive on heads but they were stock on it from the 2005 Silverado. i'll find out .
were pretty sure there is a couple tenths left with the current tune/boost . the engine was running in the truck 2 weeks ago and this was the first outing with it in the Camaro. but the Camaro is known to work and get good et,s with any engine in it.
the triple 12 was pulling good to 6600 in the logs. good cam.
