427 LS7 whipple charged build questions?
Ok, I have a customer wanting us to build a 427 super charged power plant for his 1977 Jeep. The Jeep currently has a 383ci SBC, Procharged @17psi. He wants more HP and the stock block is his current limitation. I have never built or done a LS7 build so I am asking for opinions and real world input on what would be a good plan for this setup. Customer would like 1,000HP reliably and he has zero LS parts for this build. I am thinking about buying a longblock and then just adding cam, headstuds, injectors, Holley EFI etc.. It will have a Th400 and 3000-3500 custom converter, currently has built 9' with 3.70 gears and 35" tires. It has 4 link front and rear and is just a 2wd street toy. This is what Im thinking so far...
427 7.0
Whipple blower
120# injectors
Holley EFI system
Blower cam/springs
Headstuds
accessories
Upgrade fuel system
427 7.0
Whipple blower
120# injectors
Holley EFI system
Blower cam/springs
Headstuds
accessories
Upgrade fuel system
For the torque a 427 Whipple would produce, the iron LSX block would be the most sensible route.
You could use about any head/cam package you wanted and it will easily make big power.
http://www.thompsonmotorsports.net/i..._31_33_440_502
Or are you looking to do it on the cheap ?
After pricing everything needed to do a 427 I think it may be more feasible to do a 390ci setup using a 6.0 block and a 3.8" stroke crank. I dont think he realized how much a 1,000HP Blown setup costs, about $30k! So I think we will shoot for 850-900Hp LQ based setup which will be a lot cheaper.
Make life simple....use stock stroke. Once you go 3.8" nobody makes off the shelf parts.
Get good heads and either go ARP625 studs or upgrade to 1/2" studs.
Whether the blower itself can be blamed, or the design and implementation of it...is harder to say. One way or another, as long as you have room, you should be able to build a setup that does not slip. It may take 10, 12, 14 ribs, cog or whatever...but it can be done.
GM's COPO Camaro race cars with the 350SC have zero problems with the 10rib 2.9L Whipple's maxxed out. Will run 8.70's 1/4 mile over and over and over.
It is a nice, low maintenance set up that packages really well. For some reason they (GM) killed the Whipple 4.0L in 2012/13 on the COPO program. Borowski has said their 2.9L set ups do just fine on the 8 rib - no slip.
The 4.0L and 4.5L may be different. I would stick with a serp set up for a street/strip car.
Slip is a matter of pulley sizing and configuration. On the sort of completely custom setup the OP is looking into, this should be sorted before the build is even started. I'm guessing in your case you are trying to get more boost than the factory "kit" was designed for. I know my comment doesn't really answer you question, but it seemed relevant.
