Twins on SBE LQ9 - BWS366's, ON3 70's, ??
My head hurts from all the reading and searching and I still can't come to a decision. I plan to buy the CX Racing kit, minus the turbos since I want to get a little better quality compressors.
Specs & Goals
80 Malibu @ 2900#'s w/o driver
TH400
12 Bolt with 3.31 or 3.42's
SBE LQ9, using stock 317's and will upgrade the springs, studs
Truck intake
Custom cam - Tick? LJMS?
Goal is high 8's, low 9's
HP wise, I think 700RWHP should get me there
No meth or water inj, plan is running straight 112-116
I know a large single would do it too, but I want twins, have tons of room for them.
Will be a purpose-built drag car, no street.
Specs & Goals
TH400
Truck intake
Thanks all. I Think I'm going with twin Airwerks S300SX3 Turbo-66mm-T4-Twin Scroll-0.91 A/R P/N 177275
Turbo Specifications:
Compressor Wheel Inducer Diameter (mm): 66mm
Compressor Wheel Inducer Diameter (in): 2.6
Compressor Wheel Outer Diameter (in): 3.6
Turbine Wheel Outer Diameter (mm): 80mm
Turbine Wheel Outer Diameter (in): 3.14
Turbine Wheel Exducer (mm): 73mm
Turbine Wheel Exducer (in): 2.89
Turbine A/R: 0.91
Turbine Inlet Style: T4
Scroll Type: Twin
I see them on ebay for around $580, but would much rather support a sponsor. Who has the best prices?
I figure these with a pair of JGS 40mm wastegates and single JGS 50mm bov should do the trick.
Turbine A/R: 0.91
Scroll Type: Twin
Turbine A/R: 0.91
Scroll Type: Twin
Turbine A/R: 0.91
Scroll Type: Twin
Just started my twin turbo build and will be using the same s366 turbos, did you decide on an intercooler I have heard this one "Treadstone Performance TRTT 1000HP Twin Turbo", is a great choice has anybody else used this intercooler ? I was going to use the truck manifold but have a TBSS intake coming tomorrow it looks to be 1/2 -1 in shorter and has better flow, will be running 3.42s as well.
