SBE Record 7.92 and still going!!!
Old Jul 23, 2017 | 11:59 AM
  #61
2muchboostNY's Avatar
Am i wrong guessing its a Gen4 4.8? In to see more results with the new setup.
Old Jul 23, 2017 | 12:10 PM
  #62
sillysspeed's Avatar
Shew weee! Those poor rods with 1000+whp and 8k Rpm's. Awesome results tho.
Old Jul 23, 2017 | 01:13 PM
  #63
Rudy72's Avatar
Running the Garrett GTX5518r, that's always been a bullet proof Turbo and should up his power with Great Heads and RPM since he is lacking in cubes... in for KickAss results!! What hot side A/R is he running at them cubes? I'm building with the same Turbo, yet going 400 cubes or more ;-)
Old Jul 31, 2017 | 08:18 AM
  #64
hellbents-10's Avatar
4.8 record done!
Off the trailer 7.94
Then 7.91@170
5.08 to the 1/8th
He says it will go 4.90s no problem with some more time on it.
Old Jul 31, 2017 | 09:10 AM
  #65
ls3fox's Avatar
7 Second Club
damn he's a monster lol congrats
Old Jul 31, 2017 | 01:08 PM
  #66
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Amazing.
TJ I can't wait for the cam for the '67!
Old Jul 31, 2017 | 03:49 PM
  #67
1320king's Avatar
Damn!
Old Jul 31, 2017 | 11:21 PM
  #68
kwrench61's Avatar
That's just crazy on stock block ****!!!
Old Aug 1, 2017 | 09:43 AM
  #69
tblentrprz's Avatar
Originally Posted by hellbents-10
4.8 record done!
Then 7.91@170
5.08 to the 1/8th
Block fill?
Old Aug 1, 2017 | 09:44 AM
  #70
No block fill.
Old Aug 1, 2017 | 11:09 AM
  #71
ls1curt's Avatar
Very impressive! You guys make it look easy.
Old Aug 1, 2017 | 12:33 PM
  #72
Stampede4ever's Avatar
Stock Ring Gaps?
Thanks.
Old Aug 1, 2017 | 12:39 PM
  #73
I think .027-.030
Old Aug 3, 2017 | 11:41 AM
  #74
Forcefed86's Avatar
I might be face book retarded… but I can’t seem to get that face book video link to work.
Old Aug 3, 2017 | 12:07 PM
  #75
I think I am also FB retarded so I pulled it lol.
Old Aug 14, 2017 | 04:11 PM
  #76
roastin240's Avatar
Any updates on this?
Old Aug 15, 2017 | 07:01 AM
  #77
He has his V 2.0 L33 in it as of last night up and running testing two step. The 4.8 must have been eating piston skirts as he was getting aluminum in the oil. He bailed before it got bad, made some more 7.9-8.0 passes in it though.
Update last night on the new cam profile. He says it builds boost a bit quicker and uses more fuel so it must be making more power. His original l33 cam was designed around a BW 96mm turbine. Now he has the GT55 with a 112mm turbine so I changed the valve events accordingly. We will see how this one does as early as Friday I am sure.
Old Aug 15, 2017 | 08:02 AM
  #78
foose04's Avatar
Awesome stuff, looking forward to more updates.
Old Aug 15, 2017 | 02:31 PM
  #79
SLOW SEDAN's Avatar
Love watching this thing progress! I assume larger cam for the larger turbine?
Old Aug 15, 2017 | 04:11 PM
  #80
roastin240's Avatar
Maybe not larger but just moved valve events? Probably opens the exhaust valve later since pumping losses are not as concerning with little exhaust back pressure. Maybe a tighter LSA and more overlap as a result. Just thinking out loud
