Astor Bracket
Old Nov 6, 2016 | 07:04 AM
02NBMFormula's Avatar
Default Astor Bracket
Im looking into the aster bracket and wanted some feedback from those running it. I cant figure out if it buts the blower in the same location, i.e. will all the piping still line up, any clearance issues?
Havent played with the car in about 5 years so if there are any new procharger tricks out there, let me know!
Basic procharger specs are D1sc, 14 psi, EPP FMIC, EPP cam, meth, ATI race bypass.
Thanks!
Old Nov 6, 2016 | 11:48 AM
Husker98's Avatar
Mounting and positioning is the same as the factory J-bracket. It utilizes a pulley on the bottom standoff for more belt wrap and a factory ls1 accessory belt tensioner to keep consistent tension on the belt as it stretches with the increase in load/rpm. If you haven't already, check out the description on brutespeed.com
Old Nov 6, 2016 | 05:32 PM
ramairetransam's Avatar
yeah its all the same, i went from a sdce to an aster and love it . Havent changed the belt in two years. Good luck finding a used one , you will probably just have to buy new.
Old Nov 8, 2016 | 01:04 PM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
http://shop.brutespeed.com/Aster-Aut...er-Bracket.htm
I sell the Aster bracket at this link. Thanks. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Nov 10, 2016 | 11:37 AM
white01ss's Avatar
Absolutely love the Aster bracket. Been running it for 4 years now. Had a bearing go bad on the tensioner pulley which was easy to fix. Be careful about old belts, I just broke a green stripe last weekend after almost three years without changing it.
Old Nov 11, 2016 | 08:41 AM
The Alchemist's Avatar
UNDER PRESSURE MOD
I'm using the aster bracket and spinning an F1a with no problems at all.
Old Nov 12, 2016 | 06:32 AM
NitrOmm's Avatar
Through the entire build, this was one of the few pieces that was a pleasure to instal. Well made, fitment is spot on & it works like a charm.
Call Bob. He will take care of you.
Old Nov 12, 2016 | 08:03 AM
LS1Tech Sponsor
Thumbs up
Thanks, I appreciate it! Bob
__________________
Old Nov 12, 2016 | 10:07 AM
Ordered one from Bob this week! Thanks for the feedback
