On3 billet 84 thoughts
The turbine housing also seemed a touch bigger then the 7875, not sure if its just casting differences or it actually has more volume.
Do you know the exducer size on that compressor?
Asking a lot of a 75mm wheel to turn that big sucker! What diameter is the shaft on that unit? Super common for the diesel guys to snap the shafts with big wheels and splits like that. Hope it’s awesome though!
They need to stick that compressor on the T6 Borg clones with the 87mm exh wheels.
I had the cover off but didn't measure, it flares out pretty good but not extended tip.
On3 says the billet 84mm wheel weighs less then the cast 78mm wheel. They also say it spools up faster then the cast 78. I will keep an eye on my logs for comparison as the cast 78 was really quick into boost. Shaft appears to be same diameter on both.
Agree, even better wish they would do a billet 84 with 88/96 T4 unit for space limited guys!
I've already fit a t6 Borg in my engine bay but couldn't route the exhaust anywhere that wasn't redicoulous for a family car. Smaller turbo with a smaller downpipe back to dual exhaust make going fast more livable. But if I didn't want to fab anything I wouldn't have done a manual swap...
FWIW I just cut the goofy huge marmon flange off my VS racing S480. Then mig welded a 4” Vband on the housing. It literally dropped in place of my T4 setup and the old 4” exhaust bolted right up with zero modification. I did have to notch and box the frame in under it to get the turbo itself low enough to bolt up to my old existing hotside. Used a T4 to T6 flange from ebay and welded it directly to my old T4 flange. It was tight, but my existing drains and induction piping worked as well.
