Making the switch.... Turbonetics to On3
Old Nov 22, 2016 | 12:30 PM
  #61
oscs's Avatar
Originally Posted by Game ova
Ohh lord....here they come.
Come on dude it was waaaaay to easy lol
Old Nov 22, 2016 | 12:55 PM
  #62
Game ova's Avatar
Yeeeaaa, I know. From what he's saying though, sounds like his turbo doesnt really have anything to do with his issues right now. Sounds like his motor just happened to get hurt after his turbo install. Turbo was puttin in so much work, it crippled his motor.
Old Nov 22, 2016 | 01:26 PM
  #63
oscs's Avatar
Yeah I don't honestly believe the turbo had anything to do with it. Just teasing.
Old Nov 22, 2016 | 03:58 PM
  #64
408-99-f's Avatar
Originally Posted by LS325ci
when you say all around, do you mean all over the engine bay? like it came out of the dipstick?
if so sounds like a blowby, how many miles did you have?
the other question is did you plumb the crank vent properly?
All around the filter on top of my catch can, like crank case pressure was excessive.
I got the motor used, from a friend. I know it doesn't have alot of miles. But it is what it is, ran great for a while. It should have been good to go for a long time though.
I have large lines from both valve covers to my catch can too. Is that what you are asking?
Also it seems to burn crazy oil at hot idle. Going down the road seems fine??? I'm thinking it's a ring issue. But I will leak down test it Wednesday night.
Old Nov 23, 2016 | 10:44 AM
  #65
LS325ci's Avatar
Blow by youll know since if you get on it, it will spray oil all over your engine bay again.
yea thats what im asking, a lot of guys run an open vent setup and its fine for short term but i dont think its sufficient for long term daily use.
A proper setup will have two catch can SEALED no filter venting.
from valve covers to catchcan to one way valve to a port After the TB.
another lines from valve covers to catch can to the FRONT of the turbo pipe.
what this does is remove positive pressure that leaks though and is removed via vacuum at non boost(like how its setup from factory)
BUT
under boost the intake will be pressurized so youll use the turbo like a vacuum.
Ive had issues with filter venting in the past on my DD that caused blow by.
Basically the vented(two of them) got restricted flow, it got clog from oil "evaporation" and dirt from outside sticking to it.
When I say evaporation I mean those "wetness/condensation due to oil"
Old Nov 23, 2016 | 11:44 AM
  #66
yenkomike's Avatar
if you are running a pcv valve you have to make sure it has a check valve built into it or it will pressurize the engine in boost. also there is a vent line from behind the throttle body on the pass side that needs a check valve or just block it and get a breather for the oil fill cap. .if you have the restrictor instead of a pcv it will need a inline check valve so boost wont fill the engine. if boost gets into the engine they always blow the dipstick out and oil the hell out of the engine.
Old Nov 24, 2016 | 02:52 PM
  #67
rt338b's Avatar
Originally Posted by yenkomike
car runs on microsquirt and a cheap $80.00 turbosmart manual boost controller. with a 10 lb spring and the controller does the rest. engine is a 05 truck engine intake and all with stock48s triple 12 cam and springs. the 78/75 turbos might not be best for peak hp numbers but I think we can get it in the 5.90s with a $399.99 turbo.
I have a 5.3 on microsquirt with same cam and inners could you send me that tune. pm sent
Thanks Rick
Old Feb 11, 2017 | 07:59 PM
  #68
MY_2K_Z's Avatar
On3 turbos still doing work? Just figured I'd bump for all the haters.
Old Feb 11, 2017 | 08:25 PM
  #69
Game ova's Avatar
Yez zirrrr!! I have an on3 that will be taking my full weight f body into the bottom 9s when I finish the drivetrain and put timing in her.
Old Feb 11, 2017 | 08:56 PM
  #70
MY_2K_Z's Avatar
Hell ya china turbos FTW! Hoping to get into the 9s with mine as well
Old Feb 11, 2017 | 08:58 PM
  #71
Game ova's Avatar
Change your language. You WILL be in the 9s, just a matter of how deep.
