Turbo for 5.3
Old Feb 17, 2017 | 03:13 PM
  #81
Ogoz23's Avatar
When you build the cold side and you are cutting the pipes to fit. When connecting them with silicone couplers, are you guys welding a ridge around the pipe so the coupler doesn't slip out or the clamps are good enough to hold it in place
Old Feb 17, 2017 | 04:08 PM
  #82
truckdoug's Avatar
Yeah I welded ridges, but you can roll a bead on them. There's some good diy ways to do it
Old Feb 18, 2017 | 08:49 AM
  #83
simple's Avatar
I've seen guys take these style wire crimpers....
Amazon Amazon
and cut the front cutting portion off them all the way back up to the large tooth crimping section. Then use that large tooth crimping section to crimp a bead in thin cold side aluminum piping.
Old Feb 18, 2017 | 02:29 PM
  #84
Ogoz23's Avatar
That's a great idea .. thank you for that video and link
Old Feb 18, 2017 | 03:08 PM
  #85
Modchevelle's Avatar
I made mine with a muffler clamp and a vise grip with a washer welded to it so you can put the tool in a vise to rotate the pipe.
Old Feb 18, 2017 | 05:32 PM
  #86
truckdoug's Avatar
nice work man. thats legit AF
