ProCharger Announces New & Upgraded D1X and P1X
#61
looking forward to Detoxx's new build!
#63
I think with a 383 you could pully for max blower rpm at peak engine rpm. that was the mistake i made and I pully'd my D1 to hit max impeller at 6800rpm where my cam was spec'd to peak and didn't realize the 427 would out flow the blower so far.
Thats the plan, I do want to see what the little D1 can do on my 383ci before I trade up for a F series.
#64
#65
8 Second Truck Club
I got the truck dialed in pretty good with the F2 spinning it very slow at 42000 rpm which is only about 58% of max recommended speed.
You can look at your V/E table and get a pretty good idea of where the motor is making peak torque. In the Holley EFI you can overlay a line on the V/E table to see where the motor was during the run. The place where you are seeing the highest value (for fueling) is typically where the motor is making peak torque. On that particular pulley set up, the blower was making only 17 psi at the shift (7400 rpm) and the V/E table was showing peak torque right around 7000 rpm.
Just an fyi for you guys to help understand how a centri set up will raise peak torque rpm up significantly. It's simple due to the nature of how the centri increases flow with speed.
If I was to run my F2 at max speed, I'm not sure it would ever make peak torque before blowing the fenders off the truck.
#69
yeah, live and learn. cam was custom spec'd by LME for the complete setup so should have been done by the best in the business. My blower just super small for the motor. Jealous of the f1x guys with the perfect up and right power curves.
#74
The P-1X isn't going to make as much torque down low as a P-1SC-1 does, so it isn't going to be the blower for everyone. Heavier vehicles will do better with either the P-1SC or the P-1SC-1. I don't know if this is also true with the D-1X yet or not. Thanks. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
