FI Built Motor
Old Jun 23, 2004 | 02:54 PM
CHRISPY's Avatar
couple of guys have posted a 110 pound difference between stock alum and stock 6L iron block
Old Jun 23, 2004 | 03:01 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I find that hard to believe. I did see SLP post that they say it's 100 lbs.
Old Jun 23, 2004 | 03:24 PM
taqwache's Avatar
although i have a nitrous motor, i went with an iron block for the same reasons. cubes, strenght, cost, and the fact that i had on laying around. on the strenght issue, i have seen plenty of LS1s in machine shops because of cracked sleeves. i have also seen several that would break pistons and due to the extra pressure, crack the sleeve at the same time. if those were iron motors, they could but be bored if the walls got hurt. although i would rather have a darton sleeved aluminum motor if i had the money. oh yea, and i was able to squeeze 380 cubes out of mine with the stock crank offset ground down to a 2.00 SBC rod journal
Old Jun 23, 2004 | 04:23 PM
XtremeLover1999's Avatar
Well , I would recomend APE . They were very helpfull and they doesn't roush you when talking on the phone . They take their time with you . They are building me a 408 motor that have :
callies 4 inch crank
callies ls1 specific rods
diamond piston ( 9.1 compresion )
ported oilpump
242/248 dur , .6xx/.6xx lift , 114 lobe sep ( not sure about this )
chromoly pushrods
APE 6.0L race heads ( 2.08/1.60 valves )
WAR intake manifold with 90 degree elbow
bla bla bla....
All this will be in an little truck (single cab S10 Xtreme)
It is gonna have a procharger F1 blower with FMIC and procharger race bypassvalve and an dry shot nitrous on top of it .
The motor should be ready this week and shipped next week .
Go APE , there good people
Geomar
Old Jun 23, 2004 | 09:00 PM
1dirtyZ's Avatar
i thought the ls1 had a "out of the hole" deck height of .006 ?
i gues on the calc you could put .0001 and subtract .006 from the gasket thickness.
Old Jun 23, 2004 | 10:00 PM
MECHAM's Avatar
its the iron block...not sure if they are the same??? as far as deck height out of the hole.
thanks all for the feedback...looks like APE has the majority so far..
Old Jun 24, 2004 | 08:27 AM
427's Avatar
427
Mecham,
We can build most common forced induction engines to ship in 3 weeks or less.
Also have 6.0 shortblock with CP blower pistons (-12cc) and Manley 6.125 4340 rods on the shelf. HP level 900hp or lower. 3087.00
Also have 6.0 shortblock with Lunati 4340 crank Callies rods and Mahle turbo pistons (-28.5cc) HP level 1300 or lower. 5302.00
These engines are in stock ready to ship.
Kurt
Originally Posted by SC-MECHAM-WS6
i am looking to get a forge iron shortblock.
just want a consenses of who has a built short block from which sponsor.
please state
engine size - aluminum or iron block
time of arrival approx - day u ordered to day it actually showed up
cost
any problems
Old Jun 24, 2004 | 08:33 AM
CHRISPY's Avatar
AFAIK Its true though
I used to think it was 60-70 pounds as well.
I think valvegod weighed them before as well...
Old Jun 25, 2004 | 01:08 AM
stage274's Avatar
your talking about the new ls1 engine girdle, yeah you do not need to run an Iron block any more, I am the engineer who devoloped it, I am the only person you can get it from , as I am going to recieve the patent for it, I am selling them on ebay check it out (under seach type in ls1 engine girdle), it boxes in all the mains, decreases windage, less friction in the piston area, and increases tortional rigidity, just an awesome piece.
