Took my Turbo SBE 5.3 C10 to the dyno
Nice truck. Any build thread?
https://ls1tech.com/forums/conversio...bed-build.html
Hey, great work man!! I love watching this setup!!
I noted the use of 706's. I was just wondering what others have done with these with larger 80mm+ turbos.
What AR turbine are you using?
So what does it do minus the CO2 on gate alone? Is 5.5psi the limit?
I bought the cam from a guy on here. I need to look at the specs but I think it is a 115 LSA and 606." left on intake and exhaust. I didn't know what I was doing but bought it and tried it anyways. I am running the stock truck intake and rails with 80# injectors. I believe the AR is 1.32. I bought the turbo used and that is what I was told it was. As for the CO2, I thought it would be cool. I have it wired on a three position switch so that when it is off it is running just on the gate which builds 7#'s. Then if I switch it stage one, it adds 3 more #'s on top, switch it to stage 2 and it adds 13#'s. I have only tried that on the dyno so far. On the dyno I took 110 sunoco, but cruising around on the street I just run 91 and meth. And Narxoleptic, thanks for posting the build thread.
Here is my first video on this truck
