holley touch screen mounting in f body
Old Dec 21, 2016 | 12:40 PM
lmt0705's Avatar
Default holley touch screen mounting in f body
i know this may be the wrong forum but a lot of us run these here. Im looking for pictures and ideas on how to mount the holley 7in touch screen into my 4th gen transam dash.
thanks!
Old Dec 21, 2016 | 01:45 PM
323z's Avatar
Ducktape it to the steering wheel, it's just a 4th gen.
Sorry I am no help, this is where I will put my 7' holley screen in a Z, a 350z.
Which doesn't help you at all. Name:  DSC05108_zpsrhxb9d18.jpg
Old Dec 22, 2016 | 08:16 AM
lmt0705's Avatar
Nope, looks cool though
Old Dec 22, 2016 | 09:27 AM
RedRocketZ28's Avatar
If you're on Facebook look up Los Vasquez. I know he made templates for the smaller screen but not sure about the bigger one.
Old Dec 22, 2016 | 09:52 AM
oscs's Avatar
I talked to him last night after seeing this post. He doesn't make them anymore.
Old Dec 22, 2016 | 11:08 AM
I tried! LOL.
Old Dec 22, 2016 | 11:20 AM
oscs's Avatar
I tried! LOL.
We where thinking the same thing
Old Dec 22, 2016 | 12:52 PM
SoFla01SSLookinstok's Avatar
Not a Holley. Just for maybe an idea.
Old Dec 22, 2016 | 10:17 PM
MUSTANGBRKR02's Avatar
Mine will be going where the radio was
Old Dec 23, 2016 | 08:09 AM
lmt0705's Avatar
I'm going to play around with some abs plastic and see if I can mount it where the stock gages were
Old Dec 23, 2016 | 08:26 AM
Keep the thread updated so the next guy can find it. Mine will be going in as soon as it comes in after the first of the year.
Old Dec 23, 2016 | 07:01 PM
Fat Jesus 808's Avatar
Old Dec 23, 2016 | 07:05 PM
So kinda like that?
Old Dec 23, 2016 | 10:19 PM
ta02zx10r's Avatar
What size of screen is that one
Old Dec 24, 2016 | 12:06 AM
The 7" touch screen
Old Dec 24, 2016 | 06:29 AM
NitrOmm's Avatar
After removing the cluster, there is plenty of room to mount. I plan on taking the plastic/glass part of the original cluster & cut out the center to the exact size of the screen & use that as the filler for either side of the screen. It already has the perfect concave & fitment.
I will have it dipped or just painted from the inside. Should clean up nicely.
Old Dec 24, 2016 | 02:08 PM
Looks good
Old Dec 25, 2016 | 10:17 PM
lmt0705's Avatar
How is the screen mounted? I've almost got mine done, I took a piece of abs and screwed it to the bottom tabs on the from bezel then took a torch to the plastic on the sides and was able to make the plastic bend and close the gaps on the sides. I haven't cut the hole for the screen yet, I was thinking I'd make a mount off the fiberglass framework and slide the bezel over it
Old Dec 26, 2016 | 11:57 PM
I used abs plastic and it bolts to the stock cluster bolt holes. And the dash is bolted through the abs plastic from the back. I just cut a little hole for the USB and can cords to go through
Old Jun 8, 2017 | 03:03 PM
WS6HUMMER's Avatar
You have any pics? I'm about to try to mount mine.
