Water mister in front of the FMIC.......does it work....?
Old Jan 29, 2017 | 02:22 PM
LS6427's Avatar
Depends how it is all setup and tuned. Potentially yes bad things can happen...or none.
Depends on what kit you buy and how you set it up. But most kits will inject based on boost pressure.
As for which...they're all fairly similar really.
IMO Aquamist offers the best kit in terms of features and safety.
Prometh/IAS make very good stuff and have some excellent tanks.
Many seem to love Alky control, although no idea what it does any differently or better than any of the others.
Devilsown also make decent stuff.
Really...the choice is up to you.
So, what kind of power gains does a Meth kit provide.....just basically.
Say I make 1,000 RWHP without a Meth kit and just a FMIC.
What could a Meth kit gain me...?
Old Jan 29, 2017 | 02:29 PM
stevieturbo's Avatar
Depends what fuel you had been using, whether the engine had been knock limited with regards timing because of the fuel/boost/CR/charge temps combo etc.
if you had already been running say E85 or race fuel and had a very efficient setup, then probably no gains.
If you were on pump fuel, lots of hot air and generally everything was bad forcing timing to be nowhere near optimal, then you could see substantial gains.
Old Jan 29, 2017 | 02:42 PM
LS6427's Avatar
Its not together yet. I'll be using full time E85. I have everything accept the turbo, which JZ will be building for me soon. When I get home from the Middle East in about 3 months its all getting installed.
So I'm just looking into a few little things, and a Meth kit was one of them.
If it won't really do much I might as well skip it.
Old Jan 29, 2017 | 03:01 PM
If you're running E85 full time and you have a good IC core then unless charge temps are getting very high, there probably isnt any point.
Although keeping things totally safe, you could just add a small kit but dont actually tune for it. That way if anything did go wrong there would be no untoward effects. But it would still assist keeping things cool on very hot days.
But I'd probably just run it first without, keep an eye on charge temps etc and see how things fair.
Old Jan 29, 2017 | 04:29 PM
1500HP's Avatar
We never tune with the meth it's a bonus , but the last thing u want is to go ***** out raged edge tune with meth , and it not spray , I had a Ron Shearer intercooler basically two 3 in garret cores welded together made 1200 on pump thru a 4l80 at 16 pounds had way more in it.
