To intercooler or no that is the question.
If your IAT's are in check and you aren't out of turbo, theres no reason to change anything IMO. If the IC is a little on the crap side pressure drop wise all it will do is make the turbo work a little harder.
You may be down a little power compared to a better core, but you aren't out of turbo. So just turn up the boost a bit to compensate. Definitely no need to spend a mint on a "nice" intercooler if you can make your power goals without it.
a turbo setup that isn't out of turbo? Push it just enough to make up for any "loss"
Just my .02
IMO you built a turbo car... use the turbo to make power. 14lbs is nothing... turn the boost up if you want to go faster. You can push 20lbs easy on that setup... What exh wheel is on your S480?
Does anyone have datalogs showing a non-intercooled cars IATs on a similar combo? Just for comparisons sake I'd love to see them
