How cam choice affects engine heating with supercharger?
I´m still using N/A camshaft:
227/238, 0.583"/.600"
LSA/ICL: 112/108
Would a different cam be anykind of answer to this problem, or am i missguided on this?
I´ve been thinking LS9 cam or Comp 227/243, 0.614/0.624" and LSA114
What are estimates how much would be achieved on powerwise, or would it reduce heating?
Manual trans 2gen camaro, and it´s mainly in drifitng use.
Don´t remember fan specs anymore but should be enough, and this has been problem also on wheel dynos with really big fans, and also in track racing. So fan or drifitng is not the issue.
Other thing is ignition advance, we are in 10 degree range, or even under. And E85...
It just dont stand more than that.
But no one sees that cam cam / timing could be isuue on this?
If it overheats or runs extremely hot during extended runs, eg. coolant gets over 240* or oil over 280* then I would worry. Doesn't make to much sense to worry about how fast the engine warms up...heck that's actually a good thing because an engine not at operating temp is not performing properly and it's causing extra wear. So an engine that quickly gets to 210* operating temperature is preferred over one that takes a long long time.
Cam timing perhaps if it was a mile off...but the engine would probably perform badly too or show some symptoms of bad cam timing.
And you say it "should" have good airflow. It either does or does not.
And I'd also say most electric water pumps are crap, they flow nowhere near what a good mechanical pump will flow, especially at higher rpm.
So does the radiator have good airflow ?
Does the temp rise over 210degF ?
What oil temps are you seeing ?
What shape/size etc is the radiator and is the cooling system configured sensibly ?
Fans....suck, blow ? details ? do they cover the entire core, are they ducted ? details ?
You say supercharged....what type of supercharger ? details ?
Is there a possibility that there might be a pocket of air on the sensor?
