What 3bar map sensor?
Old Feb 28, 2017 | 11:07 AM
glanzergtx's Avatar
Default What 3bar map sensor?
what 3bar map sensor you guys running on the bigger boosted applications. Say 18-22 lbs. Does GM have a 3bar or do you have a source to find one aftermarket?
Old Feb 28, 2017 | 12:48 PM
slocaddy's Avatar
Duramax and zr1 are both 3 bar.
I got the duramax sensor first because it was plug and play for my intake,
The tuner prefered to tune using a zr1 sensor, so that's what I changed to
Old Feb 28, 2017 | 12:51 PM
svslow's Avatar
3 bar info
Old Feb 28, 2017 | 02:25 PM
truckdoug's Avatar
The duramax sensor gave me fits. I read it doesn't have much resolution in the 0-100kPa range.
switched to an ls1 type 3 bar from efi source, no more problems
Old Feb 28, 2017 | 05:45 PM
Dennis5374's Avatar
Im making 16 psi right now and I'm on a cobalt baro sensor. Only 2 bar but It's plug and play , and works just as it should . I also use Holley hp efi, and will do so on every single build I do for the rest of my life .
Old Feb 28, 2017 | 11:13 PM
RonSSNova's Avatar
I made my own.
One of the issues of being both a car and electronics nerd.....
Old Mar 1, 2017 | 06:09 AM
lmt0705's Avatar
I ran the Duramax one for 2 seasons with no issues, I put a holley ecu in which is why I swapped it out for theres. Guess I've got one for sale! Lol
Old Mar 1, 2017 | 07:01 AM
RedRocketZ28's Avatar
EFI Source.
Old Mar 1, 2017 | 11:32 PM
mightyquickz28's Avatar
EFI source here too.
Old Mar 2, 2017 | 10:48 AM
Narxoleptic's Avatar
EFISource is plug and play for $41 shipped....
http://www.efisource.com/shop/ls1-st...ar-map-sensor/
