What turbo for a 4.8
Probably going to be a Gen IV, stock except for valvetrain (smallish cam). I will be running 93 octane on the street and will use race fuel for track day.
I like the s475/t6/1.32 but the dam 5" down pipe make for packing difficulties.
Look at the 4.8 record holder running the S484 T6 (mxguy1286). I’m sure he doesn’t consider the power band “dirt bike like”. But you can’t expect something for nothing. Smaller engine has to rev more to make the same power. No way around it if you want an efficient setup. Turbos love RPM as well so that’s not really a bad thing.
You need a “loose” converter that’s capable. mxguy1286 ran the 9.5 PTC with the 17 stator shifting at 7200. He also ran a 2.5" hotside (which is leaving some spool time on the table IMO). Slap a nice 2", 2.125, 2.25" hotside on that T6 S475 and it will perform great. Better than the precision unit for MUCH less $ I’d bet. (If you take advantage of the lower back pressure the S475 provides.)
IMO you don’t need the 5” DP either. Keep the DP short without many bends and neck it down to a 4”. Cut the goofy 5” flange off and weld on a 4” Vband. (or get the LJMS 4” adapter) Figure the “96mm” wheel has an 87mm exducer. 120% of the exducer wheel DP sizing rule puts you right around 104mm or 4” for the DP. I just did this on the VS S480. Really wasn’t too hard to weld up a 4” Vband flange on it. More pics and details in the rx7 build thread.
I wouldn’t limit yourself to stock intakes or smallish cams either. If the budget allows it and you really want the 4.8 to shine, it needs to have the supporting parts to make good power from 5500-7800+ IMO. Kinda what a destroked engine is meant to do. More HP you make over peak torque the better. If you go with the larger T6 turbo housing you’ll have less overall back pressure which will allow for a larger cam and more RPM.
I couldn’t do all that I wanted converter and intake wise with my budget so I had to make due and pick a cam that suited the parts I was running. If you really want it to run well build it similar to mx1286’s setup.
https://ls1tech.com/forums/forced-in...6mm-notch.html
