Need help... Catch can smoking
Old Apr 14, 2017 | 01:18 AM
70c10's Avatar
Default Need help... Catch can smoking
Took my truck to get dyno tuned today. Made a half a dozen pulls with good results. It's a single turbo ls1 running 8 pounds of boost. I recently installed a Might Mouse vented catch can with both valve covers connected via -10 lines. Before the Dyno it would smoke a little at idle but I understand that was normal with no PCV. When I started it to load it on the trailer we noticed lots of smoke from the engine bay. Opened the hood and the breather was smoking like a freight train. It also seems the oil pressure is lower then it was. Do you think the motor is hurt? Not sure what to do or where to start.
Old Apr 14, 2017 | 03:05 AM
Johnv's Avatar
Start with a leak down test on all cylinders.
Old Apr 14, 2017 | 04:38 AM
stevieturbo's Avatar
That does seem a lot.
Warm engine on a warm day ?
Old Apr 14, 2017 | 06:16 AM
forcd ind's Avatar
Did you drain the catch can, see how much oil was in it.
If a high vol pump, I wonder if you filled the valve covers up with oil.
Def a crazy amt. of smoke. As said, I would perform a leak down, at the least run a comp test.
Old Apr 14, 2017 | 07:30 AM
truckdoug's Avatar
yeah time for a peek at the turkey. mine was doing that after I busted ring lands and had two spun cam bearings.
Old Apr 14, 2017 | 10:39 AM
Redbull87's Avatar
Yup thats the same i had on my last lq4 when i busted ringlands.The motor ran fine but the smoke got worse and worse.Like mentioned above..maybe you filled the catch can and it needs to drain or you have a hv oil pump and excess oil sitting at the top of the heads but for sure check comp/leak down test.
With my current lq4 and same setup..my catch can doesnt smoke at all..barely anything in boost either.I check the catchcan every 2 weeks depending on how much I drive the car.
Old Apr 14, 2017 | 10:41 AM
dburt86's Avatar
I have no sound, but that looks like its happening at idle, in which case, motor is hurt.
During a pull, that wouldnt concern me.
Old Apr 14, 2017 | 11:57 AM
70c10's Avatar
Yes it's at idle.
Old Apr 14, 2017 | 05:16 PM
Game ova's Avatar
15mm on the bellhousing bolts...10mm manifold bolts....I think the long motor mount bolt is 18mm. See where I'm going with this?
Old Apr 14, 2017 | 05:21 PM
ls3fox's Avatar
7 Second Club
haha its kinda fucked up but its funny
Old Apr 14, 2017 | 05:55 PM
forcd ind's Avatar
I am building a 70 step side now, those hoods are heavy
Old Apr 14, 2017 | 07:41 PM
drecpt83's Avatar
Damn lmao!!! I'm about to go for a drive and a little "street tuning" . knowing my luck, I Think I'll just set my hoist up now
Old Apr 14, 2017 | 07:51 PM
truckdoug's Avatar
im not sure if they got heavier or I got older but I use ratchet straps and a cherry picker nowadays
Old Apr 14, 2017 | 08:03 PM
70c10's Avatar
Where you located maybe you can lend a hand hahahaha
Old Apr 14, 2017 | 08:04 PM
Game ova's Avatar
Nah, you'll be fine. But if you see smoke like OP after the tuning session.....set the hoist up.
Old Apr 14, 2017 | 08:05 PM
70c10's Avatar
If it ends up being rings would it be better to buy a new short block or rebuild the current motor with forged internals.
Game ova's Avatar
Seriously, if I lived near you....I would in a heartbeat. I hate seeing a guy having motor issues.
Old Apr 14, 2017 | 08:07 PM
Game ova's Avatar
Build your own motor....skip these overpriced shops....and yeah, forged internals.
Old Apr 14, 2017 | 08:08 PM
70c10's Avatar
How much power /boost do you think a forged ls1 could handle?
Old Apr 14, 2017 | 08:11 PM
Game ova's Avatar
There will be people that tell you that the ls1 is the absolute wrong motor to make boosted power with, but there's one close to me that's making roughly 800rwhp....and propels a 3750lb ss to 9.30s at nearly 150.
