Main and rod bearings?
Old May 2, 2017 | 10:35 AM
Don Nguyen's Avatar
Default Main and rod bearings?
I am going to be swapping over a 24x reluctor crank into a gen iv block that had a 58x reluctor crank.
Should I even risk reusing the old bearings from the gen iv block with the new 24x reluctor crank?
If it was recommended that I get new bearings (I would most likely go with Clevite P bearings), should I measure the crank first and try to see if I need oversized ones or do the cranks typically hold their standard sizes very well if they've never had any work done on them?
Old May 2, 2017 | 11:10 AM
jimmyg's Avatar
You can just swap the wheel.
Old May 2, 2017 | 11:15 AM
Don Nguyen's Avatar
Yea, but swapping reluctors requires a machine shop and rebalancing the crank possibly, so it just seems like more work than necessary.
Old May 2, 2017 | 11:24 AM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
Just swapping a wheel doesnt require rebalancing but using a different piston/rod combo will. a 4.065 ls3 piston would weight diff from an ls1 piston etc.
I would have the crank polished and checked then put P bearings in for good insurance. They are like $120 for the set from us in stock size, 1 over, 1 under, 10 over.
Old May 2, 2017 | 12:07 PM
KCS's Avatar
KCS
Moderator
Gen III cranks and Gen IV cranks probably won't be balanced to the same bobweight, like WS6store said, so you may still have to pay for machine work.
Old May 2, 2017 | 03:01 PM
Don Nguyen's Avatar
Anyone have first hand experience swapping different gen cranks without rebalancing?
Old May 2, 2017 | 03:11 PM
Ive seen swaps like that before. Personally. They will have issues. The higher the rpm the more issues. If they are "close" you cannot tell, but honestly its better to be safe than sorry imo.
Old May 2, 2017 | 03:44 PM
Don Nguyen's Avatar
I forgot to mention that my gen iii block was an l33 that had the gen iv style rods from the factory already, so technically the only difference is really the reluctor wheel itself. Since that is the case, it should in theory be all the same right?
Old May 2, 2017 | 05:24 PM
What is the crank going in? An l33 has flat tops. The lm7 and l59 have dish on the gen3 setups.
Old May 2, 2017 | 06:19 PM
truckdoug's Avatar
just swap the reluctors. it's easy. there's a guy on here that'll rent you the tool. you'll need a mapp torch at the minimum.
and dont just throw bearings in without having someone who knows what they're doing (not saying you arent capable) check clearances.
if the oil pressure was good, and the bearings & journals look ok then just swap trigger wheels and move on.
Old May 2, 2017 | 06:46 PM
Game ova's Avatar
Best post thus far.
Old May 2, 2017 | 09:15 PM
Don Nguyen's Avatar
LC9 block, L33 crank.
Old May 2, 2017 | 09:16 PM
What pistons are you using? block doesnt matter of course.
Old May 2, 2017 | 09:32 PM
Don Nguyen's Avatar
The pistons that are in the LC9 block.
Old May 2, 2017 | 09:34 PM
Then no balance issues. Id def look at bearings though. Good insurance.
Old May 4, 2017 | 10:35 AM
Don Nguyen's Avatar
I am going to measure my bearings and double check them before buttoning up everything together.
Anyone know what the rod/main bearing clearances should be? From what I have found, the connecting rod bearing clearance should be 0.015-0.076mm and the mains if geater than 0.00212" would need to be undersized.
Old May 4, 2017 | 11:13 AM
Black_Sunshine_99's Avatar
From what I've found most guys run .0027" rods and mains with .004" end play for a turbo build.
Not sure if your boosting but that's what I've found.
Old May 4, 2017 | 11:18 AM
Would you anticipate a balance issue going from a factory dished piston to a factory flat top?
I've got an LM7 I'm putting 4.8L flat tops in and am trying to decide whether to balance the assembly or not.
Cheers!
Old May 4, 2017 | 11:20 AM
Don Nguyen's Avatar
Yea, I'll be going turbo. I should have figured that guys run slightly different specs on turbo set ups.
Any other opinions on clearances for bearings in a turbo engine?
Old May 4, 2017 | 12:56 PM
That depends on the difference in weight. Quite a few machine shops dont balance going to a .030 bore setup. I am not qualified to answer that question as a true machine shop could. If the weight difference is negligible then it would prob be ok to run it. But i cannot tell you exactly where to draw the line.
