vibration from cog drive?
Old Jun 27, 2004 | 01:23 PM
1dirtyZ's Avatar
Default vibration from cog drive?
i just installed a cog drive on my ATI kit, now at 3000 rpm i get this vibration that goes through the whole car under load or not.
what could be causing it to do this? almost feels like a bad u- joint but it isn't.
can the belt be skipping? even though i still have all the teeth on the belt.
Old Jun 27, 2004 | 02:43 PM
NA$TY-TA's Avatar
BOS was feeling the same thing and so was FRCFED and BLWNTA..... Im sure they will chime in.
Kyle
Old Jun 27, 2004 | 06:33 PM
frcefed98's Avatar
The only time mine vibrated is when the s/c cog and the alt. pulley decided to kiss. I then went to a steel bracket and didn't have anymore vibration issues. Your belt might be ratcheting. The teeth will be alright and still there, the belt just jumps teeth due to loose tension. Try a little bit more tension....
But Bos was feeling this same thing too.
J
Old Jun 28, 2004 | 01:17 AM
BIGBOS's Avatar
Yea, the vibration is the teeth skipping over the blower pulley......the teeth will be there for a while, but after many times of it happening they will wear, your best bet is to get more belt wrap with it like BlwnTA did with the extra idler, you will most likely have to reorder the COG stuff....
SDCE all the way
Old Jun 28, 2004 | 01:51 AM
nbm00ws6's Avatar
I don't think belt wrap is the answer. I've been doing a little research into this and I think we need a wider cog belt. I talked to polytech who makes and deals with cog/timing belts and are experts. They say we won't get the grip we need by going with just more belt wrap, one or two teeth won't make that much difference. They say a 50mm belt will do the trick.
Tom
Old Jun 28, 2004 | 11:31 AM
1dirtyZ's Avatar
i already have an extra idler and a steel bracket. i also have the belt tight on there, i guess i'll have to tighten it a bit more.
Old Jun 28, 2004 | 02:00 PM
BIGBOS's Avatar
I don't think making it tighter will help......
Old Jun 28, 2004 | 02:59 PM
1dirtyZ's Avatar
well i thought it was tight, or it may have loosened up after breakin.
i tightened up the belt a bit and th vibration is gone! now i have to work on the allignmet.
thank you cog gurus
Old Jun 28, 2004 | 03:18 PM
BIGBOS's Avatar
Is it gone through the whole RPM range?
Old Jun 28, 2004 | 03:49 PM
1dirtyZ's Avatar
yup!
i used to show up from 3k and above rpm. i still didn't give it a long WOT blast, just quick tire spins to 6100 rpm in 3rd.
Old Jun 28, 2004 | 03:50 PM
BIGBOS's Avatar
Thats good to hear
