Boost solenoid set up?
Old May 15, 2017 | 03:08 AM
kingtal0n's Avatar
I've tuned a few cars with the Profec.
I will say it was easy to use.
I didn't find it to be very consistent.
Everytime I have heard this, it has been 100% install error. The vacuum line needs to be dedicated on the intake, no "T's", that will fix the majority of problems with consistency.
Old May 15, 2017 | 04:33 AM
stevieturbo's Avatar
Originally Posted by Ben.
Yeah I had an eBoost street in one of my cars, they are a good thing. If it was spiking you may have had it plumbed up wrong.
Top diagram can give you better boost control and allow you to still generate fairly high boost even with a soft spring in it. You can dial it right back for the street and still wind big boost in at the track. The bottom diagram only bleeds boost off the top port, where as the top diagram bleeds off the middle and adds it to the top, kinda of doing two things at once to increase boost.
Simplest option is to do neither of those. Just put the solenoid in line with the middle port. Plumb it so that the two ports which have constant flow are going from the pressure source to the middle port on the gate.
Top will most certainly not give "better" control and will be more problematic for most as already stated. It should only be used if absolutely necessary...which for most it is not.
Old May 15, 2017 | 09:25 AM
3 window's Avatar
I can see the spiking or lack of control of the top method by not having a way to bleed pressure from the dome. There needs to be a bleed somewhere to let pressure from the dome.
Old May 15, 2017 | 09:54 AM
correct.
Old May 15, 2017 | 12:48 PM
truckdoug's Avatar
That's what, 100 or more button pushes? :-)
Ron
depends on how fat your fingers are. i miss the "simultaneous 2 button" entry into boost set up menu about 50% of the time.so for me that's be like 200+ button presses. fuggin aussies.
