LS1 Turbo Power guesses
Every application is different but my 60's ran out at about 580rwhp with twin 255's, CNC ported 317's and a turbo cam.
My fuel system is by no means optimized but file that away in the back of your head if you start running out of fuel lol.
i went with a holley regulator but i also dropped in dual pumps, bigger lines and holley rails, and 95lb injectors. Now i have fuel for days.
http://aemelectronics.com/?q=product...p-offset-inlet
I found this at least, theres probably other ones
like this one
http://aemelectronics.com/sites/defa...nt-50-1000.jpg
There are lots of ways to look at these. Just get a general feel for what it will do, then be very wary as you approach the limitation on your own vehicle. Looks like it should do something like 600rwhp no sweat, assuming you started with 44psi base pressure (which is where I usually start, or even less sometimes). The base pressure is reduced by engine vacuum when referenced, and lower pressure typically means longer pump life, so I try to use the minimum pressure possible.
Raising fuel pressure makes the injectors flow more but causes the opposite with the pump.
Currently running 11-12 lbs. with a T7875 and I have no delivery issues.
I'd say a regulator is recommended but not required, my setup has been proven to support 700whp which is why I copied it lol.
I don't know what kind of power it makes unfortunately but I'm hoping for at least 600whp.
https://ls1tech.com/forums/fueling-i...k-cheap-4.html
