Has anyone tried the FItech 70050/70051
#681
did you try the GM sensor? My FItech bosch sensor reads correctly with E0KO but in boost it was reading 1psi less than both my innovate boost gauge and the AEM truboost. Swapped it out for the GM LS9 and it works and reads perfect, it does read 112kpa EOKO but the vacuum reading and boost both correlate to my boost/vacuum gauges. I haven’t had any issues with mine just some minor tweaks and I want to say I’ve put on 500miles and all of them are beating the heck out of it so lots of boost pulls every time I take the car out.
I would be looking at the sensor, the wiring for a loose connection etc. I couldn’t understand your comment about the gauge also fluctuating? So you MaP sensor and your boost gauge (seperate) are both showing fluctuations in boost? Sounds like a dead spot almost or mechanical? Valve springs? Lifters? Are u getting knock in the boost fluctuations?
#682
#683
I own a gm map but back when I tested the two , the fitech read correctly so I ran it. I'm certainly not opposed to trying the gm map next time out for sure, good idea. It's gta btr stage 3 cam kit, shouldnt have any trouble there. Definitely efi related, the motor runs great in boost till it gets to my peak setting then it just bounces 2lbs either way. Talked to Arnie Pamment and his is doing the same and his logs show the map sensor bouncing. I see it on the dashboard when big gauges are displayed and im looking at boost/lh afr/rh afr/timing. Timing/afr are pretty solid, but boost number bounces around like the gauge in dash. It does the bounce wether peak level is set at 12lbs or 22lbs, doesn't matter just has to be wot and it'll do it
#684
neither of you guys touched the map offset chart , just plugged the gm map in and ran it?
test I did on the gm awhile back::
https://youtu.be/Ga-Vhfz9etU
I would swap the LS9 in, leave stock settings and look at the accuracy with the engine running in basic senors under datalogging. If you have a boost gauge that does vacuum you will be able to verify accuracy in real time.
#685
Ok I'll definitely pop the gm sensor into intake tonite when I get home, worth a try if nothing else ! Its not gate related, I've tested them and they're working great, sealed up great and I've added 10lb springs to both , the issue was still there, just higher boost level of course. I run a halman style mbc that is working great, I'm happy with it and have used the same brand and type in the past , got solid steady levels.
talked with Arnie and he is using the fitech sensor too, maybe that's it.
#688
OK guys, a few questions-never dreamed this thread would grow this big, lol.
I ended up using the Holly HP since there orig wasn't much info, but starting a new project,
might try the 70051.
Those using it, would you buy it again after using it.
Has it been reliable
Are most of the problems just setup problems
Does the trans control have the ability to use a paddle shifter, usually 2 wires
for up/down shifting. (Manuel mode)
I will be running a small turbo, does it work with boost OK
Thanks guys
Thanks guys
#689
That's MISTER MODERATOR
The Fitech LS systems are designed to function exactly like a GM PCM. It has controls for trans, A/C, alternator and dual cooling fans. As such, it has no used definable inputs and outputs for anything such as trans shifting.
There are many people on the FB group using these systems with turbos and most report good results.
There have been a few with issues, it's often user error and they get straightened out. One guy had a bad harness and he didn't have the patience to work it out with Fitech so he gave up, returned it and went with something else.
Fitech has pretty sketchy support, sometimes long waits, sometimes they're clueless. But sometimes you'll get through quick to one of the better people.
It's a good system and works pretty well.
#690
I've been running a twin turbo setup for a few months now. I'm running a powerglide so I can't talk about the transmission. I've been pretty happy with it so far, I've had a rich tipin that I've been fighting with but it's livable for the money difference. Mine is just a street car, when it cools off I'll try the track. I'm at 12 psi now.
#692
Yes you can.....just get it.....think about it....every time you do a mod....you won't have to pay $$$$ a tuner to re flash it.....you simply connect the hand held and change calibrations accordingly, best of all you can use on gen 3 or gen 4 motors....get it...I got 2...with no problems from either one
#698
I just got the 70051 for my ‘86 Cutlass and will start the install this weekend. I’m using an ‘06 Silverado 5.3. Since the FITech harness includes EV1 or EV6 injector harnesses Will I need injector adapters? I think the ‘06 5.3 has Multec2 injectors but I can’t get to the engine until Friday
if I do need adapters where can I get them?
#699
#700
