Has anyone tried the FItech 70050/70051
#721
#723
Hey guys. I've read through a lot of this post and it has a ton of great information. I have had the system running a 5.3 in a 95 chevy 1500. The one thing I am trying to find some info on as I have 70051 with the trans control is where do I find the line pressure table for the system. I have been looking in procal without luck and after watching the line pressure while going down the road the output value is clearly not right as it shows a value of 7 for final line pressure. Any one have any inf on this?
#724
Anybody ever have there fuel pump stay on after the 5 seconds the key is turned.....for some unknown reason mine starting acting up this afternoon when I went to go start it the fuel pump didn't kick off after priming. ...it just kept going...I tried unplugging the ecu and disconnected the battery for a while but I'm not getting any luck......wtf? Anybody ever have this issue? Thanks for your help in advance fellas!!!!!
#726
#728
I ended up having to replace the ecu :.. (...on the nova, but now I havea new problem on my c10...I swapped the glass packs for flow masters and now I'm getting a code 56 and 137.....do you think the asa cam is not getting along with the restricted mufflers now and thus that is causing my o2s to get choked up.......it wierd though cause the truck seems to run fine!!!!!
#732
Hi how u wire digital dakota dash for both speedometer to work I got ls1 ultimate system
Just got my Fitech 70051 setup, this will run a basically stock 05 GTO 6.0 and 4L65E.. I'm a little new to the LS world and am looking for a little direction.. The Fitech doesn't use a MAF but does have an IAT, what would you recommend for an IAT, stock from an LS1?
Picked up a Dakota Digital dash, Tanks setup and nice looking set of Headman headers..
Engine and trans are sitting in my 73 F Body
