Nitrous Outlet Interspooler
Old May 26, 2017 | 02:38 PM
Nitro Dave's Nitrous Outlet's Avatar
Default Nitrous Outlet Interspooler
For all the turbo and centri guys wanting a way to run nitrous on your set up and distribute very well we have your solution for you right here. Introducing the Nitrous Outlet Interspooler. This can be installed into your charge piping. If you would like to run it wet you must install it on the cold side of the intercooler. We have these availble in 3in right now and coming very quickly are 3.5in and 4in interspoolers as well. Feel free to give us a call in sales 254-848-4300 http://www.nitrousoutlet.com/intersp...e-systems.html
Old May 26, 2017 | 03:05 PM
Rise of the Phoenix's Avatar
So it can be purchased in two different ways; dry and wet?
Old May 26, 2017 | 03:36 PM
ramairetransam's Avatar
seems like a dry 50 shot would be awesome for keeping things cool
Old May 26, 2017 | 08:02 PM
Razor's Avatar
Bout time some addresses this void in the market with something simple!
How is this better than installing a nozzle in the intake track?
Old May 27, 2017 | 07:37 AM
JAX04's Avatar
Because this is way sexier then just a nozzle lol.
Old May 27, 2017 | 08:16 AM
Zmg00camaross's Avatar
This.
Old May 27, 2017 | 04:09 PM
Razor's Avatar
Sexy is an expensive option.
Old May 27, 2017 | 04:33 PM
But it's a option!
Old May 28, 2017 | 08:14 AM
Razor's Avatar
Hopefully there will be some quantifiable testing done with this kit as it is designed for this specific function.
I've read of people using a small 50-100 shot to spool the turbo and claim terrific results; Especially using a large turbo/small motor/and/or tight converter.
I'd like to see some actual data logs of decreased spool time and power gained with nitrous on a turbo LS style engine. I see more centrifugal SC and PD blower set ups using it.
Old May 28, 2017 | 04:01 PM
It works. Nitrous one cools intake charge! 2nd once in the cylinder nitrous the extra power helps build more heat and load on the engine. Things to help a turbo spool quicker. Me if the turbo is fit for a combo you really won't have that much lag.
Old May 28, 2017 | 09:32 PM
NemeSS's Avatar
Much want
Old May 30, 2017 | 08:35 AM
brandon@nitrousoutlet's Avatar
Yes. You could run it as a single stage wet, or a dual stage dry.
Old May 30, 2017 | 12:58 PM
silvea's Avatar
Is the piece that goes to the intercooler available for purchase on its own?
