Cam guys i need some help
I had a super super tight converter last year that only flashed 2500 and would make 1 psi.
I went from this
To this with the technique I described
Now I have a ptc and it doesn't matter much of what I do lol
starting compression was 175-180psi across all holes. adv 4deg popped off 210psi and advanced it 6degs and jumped up to 235psi.. the springs that are on the heads my lil spring compressor tool will not smash them down to get my p/v checker springs on.
13.5 afr to lean popping on 2step?
If i can not get the car to spool 7-9psi i will go back in and adv another 2deg.
I have been turning the engine over by hand every time i move cam. when i was on the 6deg adv there was no issue touching since, i cant check p/v clearance. i thought about adv cam 8deg which would put cam on a 108. if the engine turns over by hand with no interferance the 6deg adv should be safe i would think..
going to try fuel first I think its really close.
i leaned out the ramp from 102kpa 13.5afr 130kpa 13.1afr 155kpa 12.0 =3600rpm 2step I sit there on the 2sdtep for a sec and the afr stayed around 11.7 12.0 you could here the car start to labor once it started fating up, not enough to lose rpm but the boost did drop to 145-150kpa as i sit there never dropped any lower. at roughly 8psi should i lean it any more? I do alot of no prep racing here local i just want to make sure im not getting to lean if i just flat foot it of foot brake vs bump up on 2step.
Im happy with the way it is now far as psi/2step rpm.. leave good alone or lean on it more? thanks guys
