Cam guys i need some help
My cam is custom grind solid roller 252 260 699 701 116 staight up.
went to the track last weekend first time on new set up the car will not get out of its own way in 100ft, 1.82 60ft.
At 4000 rpm the car is nuts, just kills 28 14.5 tires like they are street tires,
Stagging car on 2step/tbrake the car will not spool up pass 2900rpm only makes 2.8psi of boost. 2step is set at 3600 the car will phisically not rev pass 2900-3000 rpm, gets up aginst the converter and will not rev.
I have tuned my own car for the last 6yrs,car has been 8.43 on a alot smaller engine combo, i have tried throwing a **** load of timing at 2step rpm and i have tried -17 deg to try anti lag, not happening.
cam guys is the cam way to big?? if i adv cam to 110 center line will this fix my issue?
Im hoping the car traps low 170s once i get it lined out should put me at 7900rpm with tire/gear set i have,
what do you guys think I should do?
With your projected trap RPM, I don't think I'd choose a shorter cam over increasing converter stall.
$0.02
You can certainly run that camshaft on a 110 to 112 degree intake centerline. If you advance it it will spool quicker.
There is a difference of thirty (30) degrees in Torque Band for Turbo vs N/A cam selection.
YOUR N/A "spec" is 282 Intake Duration (252+30), like an Indy Car with 12K RPM.
The account, your account, states this with a 4K light off.
Lance
thanks again guys will post results fri night.. i just need that lil bit to get up on the 2step. never thought about comparing comp. from straight up 116 vs putting it in at 110, will definitely be taking notes to compare
You'll pick up 40 psi of cranking compression moving the cam. its going to make a big difference. between that and getting the valve event relationships correct.
starting compression was 175-180psi across all holes. adv 4deg popped off 210psi and advanced it 6degs and jumped up to 235psi.. the springs that are on the heads my lil spring compressor tool will not smash them down to get my p/v checker springs on. so i went back to the 4deg advanced. not know my p/v clearances, i put the front of the engine back on and went out and tested.
the car responded better down low but still could not reach my 3600rpm 2step. 3200-3300 all she could do, but it did make 4.5psi on tbrake more then the 2.8 before,
so when i was sitting on tbrake up against the converter building boost as boost started climbing my afr started dropping 0psi 13.5afr 2.5psi 12.8afr 4.5psi 11.5afr at this point the engine went from 3200-3300 rpm to 2900-3000rpm. this all within 3-4 sec on the tbrake. how lean can i get the engine to keep it spooling higher. this was all at 31deg of timing on the tbrake.. I feel this was major improvement from the start. with out knowing p/v do i push up to the 6deg adv or try leaning it out first?
thanks again guys,
